Old Tue, Nov-21-2017, 04:57:28 PM   #11
e46lsb
e46lsb's Avatar
Reputation: 0 e46lsb is on a distinguished road
Default Re: Best battery tender?
It does. 7 lbs, no hassles
Depends how you want to use it.
Here's all their options:
https://smartercharger.com/accessories/
It comes with a "comfort connect", which is all I've ever needed. I have one installed on each car.
Thank you for your help on this. So if I order it, in essence itís kinda complete? Where does the comfort connect plug inv
Individual- inside and out.
Jump to top e46lsb is offline   Reply With Quote
Old Tue, Nov-21-2017, 04:58:14 PM   #12
Dirty Elf
BSME
Dirty Elf's Avatar
Reputation: 0 Dirty Elf is on a distinguished road
Interesting on the li-ion battery. Do you have a link to more info?
Any idea what the upgraded models of the CTEK chargers provide? They appear to be the same electronics repackaged at a higher price.
MSX5.0 vs MUS7002 vs MUS25000
perhaps charging rates?
edit: yep. 4.3A vs 7A vs 25A
First Road Trip
2004 Silver-Grey ///M3 Coupe
Jump to top Dirty Elf is offline   Reply With Quote
Old Tue, Nov-21-2017, 05:39:46 PM   #13
Originally Posted by e46lsb View Post
Thank you for your help on this. So if I order it, in essence it’s kinda complete? Where does the comfort connect plug inv
Wherever you want-- you wire it in (if you choose to use it).
I'm running a Braille GU1R.
https://www.summitracing.com/parts/brl-gu1r
I would suggest making sure you don't have any power draws, as the capacity is less than stock. That said, I have no issue parking the car for a week and having it fire right up. It also has had zero trouble firing up the car in cold temperatures. I've had it for ~3 years now. If I'll be parking it for more than a week, I connect it to the ctek lithium.
One of the things I really like about it is it will cut the power to the supply to the car if you leave it sitting long enough (not charging) that it has discharged-- the benefit of that is you can't discharge it to the point that you damage it. The CTEK Lithium can disengange the discharge lock when you connect it by holding the mode button for 10 seconds.
It's a bit pricey, but Lithium Poly batteries are supposed to last >2x as long as standard batteries, and it's around 2x the cost. So, long term, the cost shouldn't be more-- especially since I can't break it early by accidentally discharging it, like conventional batteries.
Looks like the actual weight is 6.4 lbs
One of my winter projects this year is to relocate the battery to the drug bin under the hood. My battery is light enough that it's not doing anything consequential for weight distribution, and the battery cable that runs to the rear of the car weights 8 lbs by itself-- more than my entire battery
Old Tue, Nov-21-2017, 05:43:18 PM   #14
Dirty Elf
BSME
Dirty Elf's Avatar
What is the weight on the mini cooper battery that is so popular as a weight reduction item? And for that matter what is the weight of a stock battery?
I'm probably due for a replacement. Have had mine for ~5 years...
First Road Trip
Old Tue, Nov-21-2017, 05:47:03 PM   #15
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
I've heard CTEK's are great battery chargers. I'm currently using a Battery Tender if the M3 sits for more than a few days. I wired up the terminal adapter to the battery and ran it out under the side cover so it's easy to plug in. I bought a $10 LED Volt meter off eBay and mounted it on the side of the tray. Works great.
Old Tue, Nov-21-2017, 06:10:36 PM   #16
According to realoem:
M3 battery: 42 lbs
Mini battery: 34 lbs
CTEK offers a similar thing, but unfortunately it doesn't work with the Lithium charger
or
Old Tue, Nov-21-2017, 06:21:31 PM   #17
mrgizmo04
mrgizmo04's Avatar
+1 on CTEK. I use the 4.3A (
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Nov-21-2017, 06:42:52 PM   #18
Dirty Elf
BSME
Dirty Elf's Avatar
this seems an appropriate thread... what are a few recommended battery replacements? (non-li-ion) or what would be the specs to look for? Does a lead AGM battery benefit from a charger like the CTEK with its desulfation process?
First Road Trip
Old Tue, Nov-21-2017, 06:57:31 PM   #19
mrgizmo04
mrgizmo04's Avatar
Here are some good threads to browse.
http://www.m3forum.net/m3forum/showthread.php?t=552358
This one has the mini battery comparsion: http://m3forum.net/m3forum/showthread.php?t=153047
Desulfation by its nature is to break up the lead sulfate crystals and reduce them (I don't think it eliminates). With the cycle CTEK has for desulfation should def help.
'05 M3 6MT coupe
Old Tue, Nov-21-2017, 07:14:58 PM   #20
Hacksaw
What broke now?
Hacksaw's Avatar
Reputation: 0 Hacksaw is on a distinguished road
Originally Posted by mrgizmo04 View Post
Same.
'02 BMW ///M3
Imola Red|Blk Cloth|6MT|FS CSL Custom TUNE -MSS54HP|CSL Replica Airbox|Euro Headers|BimmerWorld 3.5" race front Y and resonator|Hacksaw's custom 3.5" SS exhaust system w/Magnaflow and 4 tipped goodness|SGT RS-ENR Coilover Kit|Evo Sport Performance Pulley Set|CDV Delete|UUC USS & DSSR|Sparco Roadster Seats|StopTech ST-40 BBKs on all 4|Beisan Systems vanos rebuild w/original stock exhaust hub|Kirk 4 point roll bar|CF CSL Rep Trunk|GC Race F/R Sway Bars|TR Motorsports MT-1|Avin Avant 2|Seibon CF GTR Hood
Jump to top Hacksaw is offline   Reply With Quote
Discussing Best battery tender? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
