Old Thu, Feb-23-2017, 04:17:17 AM   #21
HassanEido
HassanEido's Avatar
Lebanon
Default Re: Intake elbows and filter - what's your favorite?
A csl intake is worth maybe 10 whp but k&n is worth 19,right
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Thu, Feb-23-2017, 10:14:10 AM   #22
BTB
BTB's Avatar
Originally Posted by mleveroni View Post
My personal hang up is more of how some intakes are the same basic design for all car models, works on some cars better than others.
I am not questioning the gains, I am just wondering where they come from with the elbow. I am just thinking any aftermarket elbow can only differ from stock so much. It is also interesting how much they can gain considering it is only one small piece of the intake. Just want to know what characteristics of the elbow increase performance.
I can't imagine it helps tremendously, but the silicone elbows are supposed to be smoother and reduce turbulent air. Was thinking about getting one but its $100 I could easily spend elsewhere... I'll probably stick with stock until I go either csl box or turbo
My Journal
Old Wed, Feb-14-2018, 01:40:59 AM   #23
maynard423
maynard423's Avatar
Reputation: 0 maynard423 is on a distinguished road
Iím goin back to the stock elbow with the Eventuri. I had the AFE elbow. When I removed it, I had tons of dirt in the elbow. I never felt like it had a good seal and apparently it didnít. The combination didnít fit well either. The elbow was pressing down on my heater control valve wiring connectors.
05 M3 6MT Carbon Black Vert
Jump to top maynard423 is offline   Reply With Quote
Old Wed, Feb-14-2018, 02:16:30 AM   #24
Paulo M
I too had one of these weird looking silicone elbows. Then I realized they look cheap and did nothing. Put the stock elbow back on and couldn’t be happier. Easier to keep clean, looks good, and fits so much better. I do recommend a dry afe filter (not for added power but for easy maintenance).
BREMBO BBS DIXIS
Old Wed, Feb-14-2018, 03:15:29 AM   #25
Originally Posted by Paulo M View Post
I too had one of these weird looking silicone elbows. Then I realized they look cheap and did nothing. Put the stock elbow back on and couldnít be happier. Easier to keep clean, looks good, and fits so much better. I do recommend a dry afe filter (not for added power but for easy maintenance).
Agree about the elbow. I actually felt slightly more torque going back to the paper filter (new) and stock elbow from BMC and bimmerworld (they're all the same). Kinda like going back to stock on exhaust setups (sect 2 and/or 3).
_
Old Wed, Feb-14-2018, 03:24:09 AM   #26
exodus454
Reputation: 0 exodus454 is on a distinguished road
I've been running an AFE for awhile, it's pretty non-exceptional. One day I decided to put the smoke machine on it at the shop and it was POURING out of the silicone joints. No amount of fiddling/lube/alternative clamps would get it to stop so off it came. Not a huge deal since I don't have a MAF, but still. I'm also pretty convinced the cone filter it comes with is too small, that thing got dirty REAL quick.
Now I'm back to my stock intake with a Mishimoto elbow. The elbow definitely helps the engine breathe better up top, you can feel it from ~6k+. I've also confirmed in logs that's actually flowing a bit more. Definitely lose a bit of midrange.. maybe I'll go back to my stock elbow for awhile. The silicone is a PITA to get on.
05 ZCP - 6MT >> CPI Stepped Headers - Magnaflow cats & 1 Cherrybomb - Meisterschaft Titanium - CSL software - Eibach pro kit - 15mm rear spacers - BW studs - GC Hybrid FCABS - BW Spherical RTABS - TMS front bar
Manual Leveling - Factory Xenon - Nightbreakers - ZKW-R lenses
Jump to top exodus454 is offline   Reply With Quote
Old Sat, Nov-03-2018, 08:23:17 PM   #27
/M3
/M3's Avatar
Reputation: 0 /M3 is on a distinguished road
Got bored so went ahead and installed the ECS Tuning silicone elbow + BMC filter that I had laying around for a while. Total investment is $60 and both parts were purchased on here. With a quick smoke test, I made sure the elbow was tight and snug for it to not allow any dirt into the motor. Both the BMC filter (which is the OE producer of the CSL airbox filter) and the silicone elbow looks to be good quality. I will report back after I drive the car tonight.
"Laguna Seca Blue 448. BMW nail it with this color. It defines an E46 M3."
Jump to top /M3 is offline   Reply With Quote
Old Sat, Nov-03-2018, 08:44:26 PM   #28
HassanEido
HassanEido's Avatar
Lebanon
Man I wish I could take back my posts on this old thread. I recommend the airbox end of story good luck with ur test drive
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Sat, Nov-03-2018, 08:57:40 PM   #29
/M3
/M3's Avatar
Just killing time and enjoying the low mileage E46 before it sells and while waiting on you sir (for the pilot box)
Old Sat, Nov-03-2018, 09:02:18 PM   #30
HassanEido
HassanEido's Avatar
Lebanon
Waiting on cf sheets now. Once I make one im satisfied with I'll let you guys know
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Discussing Intake elbows and filter - what's your favorite? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
