Old Wed, Feb-22-2017, 05:59:28 PM   #11
HassanEido
HassanEido's Avatar
Lebanon
Default Re: Intake elbows and filter - what's your favorite?
Originally Posted by WuBai View Post
I'm currently running an Evolve Eventuri intake and I absolutely LOVE it. Much improved throttle response and more torque that I can feel. However this point got me thinking. I'm using a Macht Schnell silicon elbow and am wondering whether I should swap out for the AFE plastic elbow that doesn't create a ridge. I would love it if somebody 3D printed a ring I could place around my manifold that would smooth out the transition so that I didn't have to buy another elbow but do you think the ridge actually makes enough of a difference to warrant replacing my elbow with another $90 piece?
splitting hairs methinks.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Old Wed, Feb-22-2017, 07:55:42 PM   #12
Is that subjective butt dyno feedback? my car has an AFE elbow and it and has a flat torque curve
Find toanster's thread where he dynos stock/hi flow filter and stock/smooth elbow vs. Each other, you'll see what I mean.
But yes, I swapped out the stock and aftermarket filters/elbows and did back to back runs and the car always felt torqueir with the stock stuff and never felt better with the aftermarket parts except at the very top end where you spend a fraction of a second.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav____________________JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped SS V1 S pipe + 200 cell HFC OE sect 2 SS Sport BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Wed, Feb-22-2017, 08:22:11 PM   #13
HassanEido
HassanEido's Avatar
Lebanon
That "felt" bit is what I'm talking about . I've dynoed before and after that elbow.. It added maybe 5whp..and lost zero torque.. and I say maybe because 5whp is within the noise. It won't add or subtract anything that you would "feel" imho. Also, a good filter with the same size as the OEM filter, will not flow more unless it filters less.. Filters like K&N will flow marginally better, but will not net any gain, like at all. I know you're not referring to K&N, but it happens to be the sh!ttiest one and filters the least, hence it flows the most(a study done a while back did show what I'm saying here).
Also dyno runs that show a difference are usually within the noise (dyno variation even on the same dyno same day etc). I also had a thread a while back referring to this study, and showing my dyno findings..
All M3 I've seen on the dyno will gain 10whps from the first to the second run, and might continue to gain the 3rd run.. I've read the thread you're referring to, but I've also done my own testing on the dyno. Removing the filter entirely(MAX flow ?) will not yield any power , ZERO I've dynoed my car ~50 times.. Short of adding cams, a stock filter will have more than adequate flow till you're >330 whp. Adding a drop in,a good one, will do zero changes to that imho at least that's what I've seen during dyno testing. So to OP, if it's power you're after, unless you've got or planning on getting cams, leave the stock box alone just my
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Old Wed, Feb-22-2017, 08:53:38 PM   #14
krakenM3
Reputation: 0 krakenM3 is on a distinguished road
I was looking at the stuff again over the weekend. Check out this link:http://www.powerchipgroup.com/stealth/e46m3.doc
Its a write up with dynos where the stock intake is compared to the K&N and the AFE and they do a separate look with a tune as well. 'Id love to hear everyone's thoughts on the conclusions. Its a very detailed report.
Here's the conclusion:
Final Analysis:
Both intakes are worth approximately 9-11HP (at the rear wheels; 12-15 at the crank) and 4-6TQ. Both intakes can definitely benefit from software tuning as AFE richens the car too much and K&N leans the car out too much. With proper software, the total net gains from either intake should range from 15-20 HP.
Jump to top krakenM3 is offline   Reply With Quote
Old Wed, Feb-22-2017, 09:26:29 PM   #15
Biohazard29
Biohazard29's Avatar
Reputation: 0 Biohazard29 is on a distinguished road
AFE Elbow and drop in filter for me. My M is a track toy so I spend alot of time up top in regards to rev range.
Walking isn't a lost art - one must, by some means, get to the garage.
Jump to top Biohazard29 is offline   Reply With Quote
Old Wed, Feb-22-2017, 09:33:58 PM   #16
suaveflooder
suaveflooder's Avatar
Reputation: 0 suaveflooder is on a distinguished road
I bought mine with a dinan, but if I hadn't, this would be the rout I would go.
2004 IR Slicktop
Jump to top suaveflooder is offline   Reply With Quote
Old Wed, Feb-22-2017, 09:40:47 PM   #17
M3 dude
Final Analysis:
i'm running a KN pod filter system, the one that has the full length tract inc. the bend. i've done some slight mods to the heatshield (i'll add a lid later on) and grafted a MAF shield from a std airbox into the tract.
in all, it sounds awesome at WOT, feels like it has abit more oomph, and i dont have any issues with running rough or anything. and a 0.2 L/100km fuel efficiency improvement.
i had a drop in bmc filter and a ecs elbow, did fa in terms of anything, really.
Old Wed, Feb-22-2017, 11:54:20 PM   #18
mleveroni
Reputation: 0 mleveroni is on a distinguished road
For the most part I am a believer that an OEM intake is better than any low range aftermarket option. I have a hard time seeing how companies like K&N can develop something better than the car manufacturer. It seems like on any car they just replace the factory intake with a pod filter and call it a day. Just my opinion.
I like the idea of an elbow since it improves on the factory intake, without completely replacing it. However I do not understand where the performance gains come from. Does it flow better from being larger or better angle? I've also heard of some cars sucking in so much air that it collapses parts of the intake but they are making huge power.
I tried a K&N drop in filter and the only thing I noticed was a poor idle. There is also the fact that it was like $50 compared to a $10 OEM filter.
2002 M3 Carbon Black 6MT
ARP Headstuds|ARP Rod Bolts|Beisan Vanos|Topspeed Exhaust|AR20's|Ebay Headers|Turner Subframe Plates|ZCP Rims|Custom Rear Strut Bar|AKG Bushings|ST XTA Coilovers|Clutchmasters FX300 Clutch/Aluminum Flywheel|RK Tune
Jump to top mleveroni is offline   Reply With Quote
Old Thu, Feb-23-2017, 12:28:55 AM   #19
krakenM3
The dynos posted shows clear gains with both of those intake options. Isn't this the evidence we've been asking for?
Old Thu, Feb-23-2017, 12:49:15 AM   #20
mleveroni
My personal hang up is more of how some intakes are the same basic design for all car models, works on some cars better than others.
I am not questioning the gains, I am just wondering where they come from with the elbow. I am just thinking any aftermarket elbow can only differ from stock so much. It is also interesting how much they can gain considering it is only one small piece of the intake. Just want to know what characteristics of the elbow increase performance.
Discussing Intake elbows and filter - what's your favorite? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
