Old Mon, Feb-05-2018, 12:20:14 PM   #161
AussieE46M3
Reputation: 0 AussieE46M3 is on a distinguished road
Default Re: CMP Auto Engineering subframe kit
Hey guys,
I'm sorry for my severe lack of presence here. I've been trying to assemble things for my project while also juggling a few other things and had a cosmetic surgery in the middle of it all.
I should have been more clear about the direction of loading. I think that might be where this is getting mixed up.
Hal,
It looks like you're right. We have been looking at things with an opposing perspective.
I understand your reasoning now. If the forces were pushing upward the shear bolt would provide some support in the way you have described however, from analysis the rear two mounts are being pulled in a downward direction by the driveline forces.
Thanks, I appreciate you having the patience to deal with my nittery. I also want to clarify that the time spent discussing it doesn't mean I think it's a huge problem, and I didn't intend to point to it as a major shortcoming. It is a solid design overall.
Not a problem. I don't mind these conversations at all and appreciate you taking the time to give input and appreciate your support.
I am more than likely all in once the 6 point race bar comes into play
great to hear folgrz! Hopefully not far off now.
Onto progress;
I've had the first batch of prototype subframe bushes made and from preliminary checks using a spare subframe and the RACP in my possession fitment seems spot on and the subframe clears the chassis by about 1mm bringing the subframe a total of 8mm closer to the chassis than stock bushes.
The goal with that being to correct the change in roll centre from adding reinforcing plates and lowering the car. Once I've had them installed into my own car and thoroughly tested I'll be offering these alongside my RACP reinforcement kits for anyone interested. The ones pictured are prototypes and do no incorporate any weight reducing features.
Also,
The parts for the first batch of front mount extensions have arrived. Fitment looks great and clears the back seats by about 4-5mm leaving space for a modified floor board to tuck between once it's all done.
unfortunetely despite receiving it on Friday afternoon, I did not install this kit over the weekend as I had hoped as I purchased a welder specifically for this project and it didn't arrive in time.
I'll likely have pictures of the install to post this time next week.
Once all that's in I'll be tripple checking my measurements and begin fabricating the 6-point brace.
Again, I apologise for my lack of activity. I'll share more with you guys as it comes.
Jump to top AussieE46M3 is online now   Reply With Quote
Old Tue, Feb-06-2018, 08:54:38 AM   #162
baders
Reputation: 0 baders is on a distinguished road
My CMP top brace kit and bottom plate kit are going in this week. Finally found a good reasonable welder in Perth. Thanks Cayn !
Jump to top baders is offline   Reply With Quote
Old Tue, Feb-06-2018, 03:45:03 PM   #163
EricSMG
40 something
I would like the basic rear bar kit + a simple bolt-in rear tower/X brace.
Possible?
2004 E46 M3 6MT SG/Black
Old Thu, Feb-08-2018, 04:17:17 AM   #164
AussieE46M3
Glad you found someone for it. Feel free to contact me should you or the fabricator have any questions about any part of the project.
Also, one thing that has recently been added to the underside plate install manual is another area worth checking beneath the rear seats where the floor meets the chassis rails just outward of the restraint clips and around the fastening points as the sheet metal can crack there as well, often above them. The last 2 cars I've seen have had it above the left most fastening point.
You'll need to take some of the seam sealer off to see it properly.
Possible?
Hi Eric,
It's certainly possible. Is that something you want now or in the future?
Would that just be a brace between the rear shock towers and the topside beam kit without the front mount extensions and associated brace lengths? I was planning on releasing a version of the brace kit in this form for sedans without split folding seats.
Once the front mount extensions are installed into my own car this weekend I'll be wrapping up the brace soon after and should have it available toward the end of next month if that's all right?
There will be a group buy on a that point in time as well so you should be able to get a good deal as well.
Old Thu, Feb-08-2018, 05:07:21 AM   #165
aznbo187
XIII
aznbo187's Avatar
Is the rear strut bar brace removable? I've had the Mason bar which I really liked, but it really limits the trunk access and makes the fold down rear seats almost useless.
no.13
Jump to top aznbo187 is online now   Reply With Quote
Old Thu, Feb-08-2018, 06:22:13 AM   #166
AussieE46M3
hey Aznbo,
Yes, the brace is entirely bolt in.
The upside to this design is that the topside beam and front mount extensions remain, still reinforcing the RACP even when the brace is removed when the full boot space is required.
Old Thu, Feb-08-2018, 07:08:45 AM   #167
e30will
Reputation: 0 e30will has disabled reputation
Originally Posted by AussieE46M3 View Post
Hey guys,
Onto progress;
Any chance of having these shorter subframe bushings in rubber/poly that's similar to stock stiffness/rigidity? I'd love to have the CMP brace, fix the change in roll center, while keeping it as close to stock NVH as possible.
Jump to top e30will is offline   Reply With Quote
Old Fri, Feb-09-2018, 10:16:22 PM   #168
aznbo187
XIII
aznbo187's Avatar
Also interested in this.
no.13
Old Wed, Feb-14-2018, 01:21:08 AM   #169
AussieE46M3
Hi Guys,
I'm afraid not. I don't think it would be possible to develop a polly bush to function in this way either.
Poly bushes transfer stress from the perimeter of the subframe hoop, through the flange, and into the sheet metal underside while stock and aluminium bushes transfer stress predominantly through the stud.
As such a poly bush would required a reduced flange thickness to achieve the reduced roll centre. I suspect if the flange on a poly bush was made thinner the splitting that occurs would become much more frequent.
On the other hand a rubber bush of similar construction to the stock rubber could be made to functions similairly however, I do not have access to the facilities required to manufacture a non solid bushing.
Old Sun, Mar-04-2018, 11:24:18 AM   #170
AussieE46M3
Afternoon everyone,
as an update for the kits we are working on, the first set of front mount extensions were fitted to my own car a couple weeks ago in addition to my own custom solid aluminium subframe raising bushes in addition to new bushes all round in the back end.
Initial review of the car is that it feels so much more rigid, more driver feedback and responsive to driver input and remains incredibly flat through the bends which both the change in roll centre and rigidity of the bushing have likely contributed towards.
IMO, for those with sufficient structural reinforcement to compensate for the undampened forces, these bushes are a must. The handling is incredible (much like an M4 if I had to compare) and my diff whine is gone now that I've removed my PF black diff bushes and fitted stock again. The change in harshness on the road in comparison the PF yellow subframe bushes is non-existent. I have only positive things to say.
I have also received pricing for these bushes to be manufactured and it is looking like I will be pricing them at ~$350 Aud (~$270 USD). I will also be including these bushes with all the RACP reinforcement solutions I offer in the group buy I intend to host when the brace is complete.
Onto the front mounts, I'm afraid my install was slightly rushed and I hardly captured any photo's to share so I hope the ones below do provide some insight into the project.
Regarding the brace, I have fitted the mounting plates and begun notching tubes to fit to form the full 6-point brace however, this may be delayed as I'm expected to be sent onto a solar farm site for several weeks in the coming days.
here's some of the pics of my recent project I mentioned earlier. let me know your thoughts or if you have any questions.
1. Base of vertical tube. The factory welds were ground down to provide a pool for the new welds material. The result is that the new weld material joins the washer at the base of the tube directly to the threaded insert within. The second shows the fitment of the tube within the structure.
Some of my welds holding the tube to the washer.
To assembly the kit, the SHS had to be first welded to the folded horizontal beam. I tacked welded it in many places to ensure no distortion then removed the piece and welded some internal joins and all extenral joins.
Excuse the glare in this pic. It was the only one I captured showing it in the car. This is before I welded the assembly in.
And lasltly, when I finally had the car fully assembled ready to put the wheels back on the ground. Not a whole lot to see but after all that work it was a big moment.
e46, racp, subframe, subframe failure, subframe reinforcement
Discussing CMP Auto Engineering subframe kit in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
