Old Sat, Apr-29-2017, 08:02:40 AM   #61
HassanEido
HassanEido's Avatar
Lebanon
Default Re: Eventuri intake review incl pre/post dyno
well let me share my experience here. I have cams, catless headers ( mods in my sig), but most importantly still using the stock airbox/filter box .
My findings on the dyno were:
-Car will top out at 335 whp with the filter box closed/sealed with the filter in it.
-Car will make the same power with the filter out with the box sealed.
-car will make ~348 with the top hat of the filter box off the bottom half. I crack it open to breathe more ..
So my conclusions were that the air feeds prior to the filter element are a restriction, or not enough. So i drilled out an additional two holes in the bottom half of the box, and routed 2x1.5 inch tubing from the box to the lower grill for cold air.. While I haven't dynoed the car, I can tell you without a shadow of a doubt that it's much better up top. I'll be dynoing soon hopefully will post back results. But my butt dyno usually is accurate. pics below, please excuse the filthy filter box. It's completely stealth, you wouldn't know anything has been added by just looking at the filter box, since the tubes sit underneath it. Intake temps are perfect, on the highway it's practically ambient temp, and driving around the city it's about 10c more than ambient.
Upper Feed:
Lower Feed:
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Sun, Apr-30-2017, 11:57:15 PM   #62
M3 dude
that's pretty backyard. props for having a go anyway. guess it just goes back to the question of the purpose of the lower duct..
i still think that csl airbox should be a mafless affair. defeats the purpose otherwise. those that would do it for underbonnet bling alone, well hats off to you...
Old Mon, May-01-2017, 06:46:40 AM   #63
HassanEido
HassanEido's Avatar
Lebanon
I agree . At the end of day you're resrticted to maf opening. I have a gsr box on the way, thought I might as well try it out. Would be intetesting if it made a diff on dyno
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Mon, May-01-2017, 10:12:53 AM   #64
digger
restricting the tube to max of 3.5" would reduce hp by 4 hp and 2 ft-lb compared to the large ~8"opening of the CSL as predicted by a sophisticated engine modelling program.
that isn't very much compromise IMO. there is really only a couple cylinders drawing air through the opening at any given time and the very large volume of the box serves to act as a reservoir smoothing out pulses.
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Old Mon, May-01-2017, 01:30:31 PM   #65
HassanEido
HassanEido's Avatar
Lebanon
I think it might be due to filter media area not just intake opening restricted to 3.5". I'll dyno with the mod i did to the filter box with and without fitler and see.. if i still gained more hp without a filter then its the larger filter media surface area that gives the csl box its advantage
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Mon, May-01-2017, 01:58:00 PM   #66
MrCooperS
Reputation: 0 MrCooperS is on a distinguished road
I believe this has already been done previously in this forum. I can't recall where/when I saw it though.
IIRC - the results were very minimal to no change.
Jump to top MrCooperS is offline   Reply With Quote
Old Mon, May-01-2017, 04:13:15 PM   #67
HassanEido
HassanEido's Avatar
Lebanon
I believe you're reffering to a test I did earlier when my car wasn't cammed. Back then it made zero difference. The thing is, after cams cracking open the filter box made a big difference, like 15 whp's worth.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Tue, May-23-2017, 10:53:48 PM   #68
T-Rex
Reputation: 0 T-Rex is on a distinguished road
Did you ever have a chance to re-dyno?
Jump to top T-Rex is offline   Reply With Quote
Old Wed, Feb-14-2018, 01:25:29 AM   #69
maynard423
maynard423's Avatar
Reputation: 0 maynard423 is on a distinguished road
Originally Posted by imran@evolve View Post
We are making something to attach the Eventuri to the Evolve Carbon Airbox which will still run a MAF.
Imagine the power gains and noise without the need for Alpha N or update to CSL software/MAP sensor conversion.
Watch this space. :-)
Did this ever ever get made?
05 M3 6MT Carbon Black Vert
Jump to top maynard423 is offline   Reply With Quote
Old Wed, Feb-14-2018, 10:28:10 PM   #70
grke36m3
Reputation: 0 grke36m3 is on a distinguished road
I remember reading this as well a few months back. A nice update would be great from evolve
Jump to top grke36m3 is online now   Reply With Quote
Discussing Eventuri intake review incl pre/post dyno in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
