Old Mon, Feb-10-2014, 03:02:26 PM   #1
Axol
Optimus Pimp
Reputation: 0 Axol is on a distinguished road
Default Auto-Dim Side Mirror retrofit from E9X
Hello,
Has anyone been able to retrofit the auto-dim driver's side mirror from the E9X?
http://www.ebay.com/itm/OEM-BMW-1-3-...item1c3b94c784
Jump to top Axol is offline   Reply With Quote
Old Mon, Feb-10-2014, 03:13:40 PM   #2
kokgo20
kokgo20's Avatar
Default Re: Auto-Dim Side Mirror retrofit from E9X
If i'm not mistaken all it needs is power for the auto dim to work, but the question is, will it fit inside our mirror covers and snap on the motor?
Build thread
Jump to top kokgo20 is online now   Reply With Quote
Old Mon, Feb-10-2014, 04:05:38 PM   #3
Axol
Optimus Pimp
I don't see the sensor so I assumed that it would be triggered from the Rear View mirror inside the car but you could be right.
Old Mon, Feb-10-2014, 04:07:51 PM   #4
Tchleung
Reputation: 0 Tchleung is on a distinguished road
Yes it can be done. You have to run wires to your mirror since that's how he e9x triggers the side mirror tint. Uses same sensor for the main interior mirror
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
462whp/311wtq @ 9.5psi(SuperFlow)
4.10 / Headers / ESS VT2-550+
Jump to top Tchleung is offline   Reply With Quote
Old Mon, Feb-10-2014, 04:46:34 PM   #5
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Interesting. Next time I need to replace the side mirrors glass I'll try these.
Old Mon, Feb-10-2014, 06:45:48 PM   #6
TheGenius46M
TheGenius46M's Avatar
Terraphantm has done this. E90 non-M prefacelift mirrors are what you need.
http://www.m3forum.net/m3forum/showp...4&postcount=18
2003 E46 M3 TiAg/Cinnamon 6MT
Karbonius | MCS | Recaro | OMP | Hyperco | Ground Control | Besian | AKG | Rogue | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Radium Engineering |
Bay Area/ Nor Cal Coding and DME Tuning Specialist. PM for inquiries.
Old Mon, Feb-10-2014, 07:17:44 PM   #7
Axol
Optimus Pimp
Thanks, I know about the mirror being a direct fit but I'm specifically interested in the auto-dim feature.
In particular, which wire from the RearView mirror will need to be tapped into to trigger the side mirror dimming function.
Old Tue, Feb-11-2014, 05:01:54 AM   #8
I haven't done the autodim mirror function. My original plan was to do just that, but after driving a BMW with the autodimming side mirrors, I realized that I don't like them since they're linked to the rear view mirror rather than having their own sensors. They're actually quite dangerous if you have tint (had to disable them on my dad's E60).
That said, the retrofit shouldn't be too difficult. My strategy was going to be to use the autodimming harness from a Z4 or X3, both of which have electronics similar enough to the E46 for the mirrors to retrofit with no drama. On the E9x+ the dimming modules are liniked to the CAS and it's just a mess to deal with.
I don't think the mirrors take straight 12v. I tried applying 12v to a set of E39 M5 mirrors I had, and they just bubbled immediately.
Old Tue, Feb-11-2014, 05:54:52 AM   #9
Tchleung
I think they were knocked down to 5 V or something.. I remember at one point I did have the wiring diagrams for the E9X and it all made sense. I'll try to look into it again if I have time at work.
Old Tue, Dec-26-2017, 07:23:10 PM   #10
nextelbuddy1
nextelbuddy1's Avatar
I just finished this on my car though i had another twist.. i have NON M zibbon cable BUS mirror motors retrofitted into m3 mirror housings but my mirror motors still have 4 ears to accept m3 glass or the E90 pre LCI Glass.
i took apart my m3 oval mirror and wired in external leads so now my mirror has 2 wire harness coming out. I made a split y cable so 2 wires can go to the driver side and passenger side.
the voltage for auto dim is 0 - 1.5 volts. when fully DIM, it outputs 1.5 volts (tested with multi-meter)
e90 pre LCI glass has 4 wires.
Red = heater +
Brown = heater -
Purple = auto dim +
Black = auto dim -
you need to test the voltage coming off your heater wires. they are not flipable.. if reversed it will read - 12 volts when activated..
the auto dimming is very welcome. im always being blinded by someone behind me and its so annoying. even with the BLUE e46 glass, it didnt help and I had to hold my hand over the glass to block light. now that doesnt happen.
I was pretty happy with this wiring job. I made all wiring independent so its completely reversible and each piece has its own harness. driver side and passenger side mirrors have their own harness which terminate in the door with the stock ribbin cable harness then a new harness goes from there through the door (I hijacked 2 empty pins in the door harness plug and used that for a factory fit and finish) I ran the harness up each pillar and into the headliner and the new output lead from the M3 mirror has its own plug which splits out into 2 plugs for a Y connection to each side.
this is why i go the junk yard to harvest stock connectors and wiring plugs/pins . it helps to have it all on hand.
IMG_20171221_010536 by Shawn Robertson, on Flickr
IMG_20171221_012531 by Shawn Robertson, on Flickr
IMG_20171221_020242 by Shawn Robertson, on Flickr
IMG_20171221_022403 by Shawn Robertson, on Flickr
IMG_20171222_011438 by Shawn Robertson, on Flickr
IMG_20171222_020251 by Shawn Robertson, on Flickr
IMG_20171222_151513 by Shawn Robertson, on Flickr
IMG_20171222_162345 by Shawn Robertson, on Flickr
IMG_20171222_165343 by Shawn Robertson, on Flickr
IMG_20171222_173537 by Shawn Robertson, on Flickr
IMG_20171222_194416 by Shawn Robertson, on Flickr
IMG_20171222_202653 by Shawn Robertson, on Flickr
IMG_20171222_203436 by Shawn Robertson, on Flickr
IMG_20171222_203715_1 by Shawn Robertson, on Flickr
IMG_20171222_204228 by Shawn Robertson, on Flickr
IMG_20171223_045127 by Shawn Robertson, on Flickr
video if the auto dim. its much more apparent when there is light showing in the actual glass like headlights etc... it gets a dark dark blue
Discussing Auto-Dim Side Mirror retrofit from E9X in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
