Old Tue, Sep-17-2019, 07:28:00 PM   #1
335dye
Reputation: 0 335dye is on a distinguished road
Default Another Will it Fit Thread
I am sure the answer is somewhere on here but from what I have seen, some say these wheels and tires will fit no issue. Others say they will rub. I have a stock 2002 M3 coupe. I am wondering if the following wheels specs will work without rubbing or the need to roll fenders. Also, i will most likely looking into lowering at some point to sit flush. So if you have insight into if that will rub, I appreciate it as well.
- Front 19x9.5" ET33
- Rear 19x10" ET25
- Bolt pattern 5x120
- Center bore 72.6 mm
- Front 255/35/19
- Rear 285/30/19
Jump to top 335dye is offline   Reply With Quote
Old Tue, Sep-17-2019, 09:19:52 PM   #2
mainstreamer00
mainstreamer00's Avatar
Reputation: 0 mainstreamer00 is on a distinguished road
Default Re: Another Will it Fit Thread
This website is a great tool to determine fit.
Head out there and measure your current setup and go from there.
Jump to top mainstreamer00 is offline   Reply With Quote
Old Wed, Sep-18-2019, 01:11:54 AM   #3
335dye
I used that site but was unsure on if it would work without rubbing or anything. (Im not smart when it comes to wheels and offsets etc). I will post screen shots of the measurements. Thanks.
Old Wed, Sep-18-2019, 01:49:01 AM   #4
335dye
Here are the images from the website. If someone can decipher this for me I would appreciate it.
File Type: gif 4D8A4714-FC41-43B7-87AD-340A3AA621ED.gif (6.6 KB, 22 views)
File Type: gif D0313168-6C88-4B27-8585-CF7B1EDABFE3.gif (6.8 KB, 15 views)
Old Wed, Sep-18-2019, 03:36:30 AM   #5
mainstreamer00
It literally tells you above those diagrams, in simplified terms, what the difference in width will be from your current to new setups.
Grab a ruler, and go out and measure from the faces of your current wheels.
Short answer - looks like these will fit.
You may have to play with alignment/camber specs and tire sizes to get everything "right"
Old Wed, Sep-18-2019, 03:56:52 AM   #6
335dye
I appreciate it. I will definitely measure. There is a good deal on a set so worst case Ill put them on my E92.
Discussing Another Will it Fit Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
