Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Old Sat, Mar-27-2004, 04:09:42 AM   #11
umnitza
Guest
umnitza's Avatar
Reputation: 0 umnitza is on a distinguished road
Originally Posted by dark_sirius
When I bought my car, they had them pre-installed from the previous owner. But he happned to give me all the reciepts and old parts from the car in a big box one day, nice of him.
Anyways... they came from hids4less.com I belive, which is now out of business, however
Go here:
http://www.turnermotorsport.com/html...UCT_ID=HID9006
Thats one place I have seen that sells a full 9006 kit for hids.
Will repeat that you shouldn't waste your money on US lights, but if you want, we've got 2-3 9006 6000K sets "lying around"
Jump to top umnitza is offline   Reply With Quote
Old Sat, Mar-27-2004, 03:15:36 PM   #12
bmw4life13
bmw4life13's Avatar
Reputation: 0 bmw4life13 is on a distinguished road
matt, i didn't realizxe you patented the dde.
Jump to top bmw4life13 is offline   Reply With Quote
Old Sat, Mar-27-2004, 03:31:17 PM   #13
Sirius
How many licks..
Sirius's Avatar
Roger that. Thing is "I" didn't waste my money on the us lights.. that was a pre-install for me. I do plan up upgrading to euros in due time. I just gotta find the right lamps and the right beam pattern, cause I am anal that way :P
More specficaly, the headlamp pattern produced by all the newer BMWs.
Looks kinda like this:
___________/----------------
Get my drift?
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Old Sat, Mar-27-2004, 04:03:12 PM   #14
custom
custom's Avatar
Reputation: 0 custom is on a distinguished road
Hey Sirius, I love those gauge rings. Where did you get them and were they a hard install?
2006 BMW X5
Sterling Grey/Dakota Black
4.4, Sport Package, Navi, Cold Weather Package, Premium Package, Tinted Sunroof
2000 Honda S2000
Gray/Black
ASA AR1's, Alpine 300W Amp, Type R Speakers, and Sub
Jump to top custom is offline   Reply With Quote
Old Sat, Mar-27-2004, 04:42:25 PM   #15
Sirius
How many licks..
Sirius's Avatar
I got them from ebay for $40 bucks actually. The install was fairly simple. They said the rings are self adheasive, but they didn't fit 100% correctly, and I ended up using glue, if you look closely you can see where I messed up. I actually got glue all over the clear plastic, but I was able to clean it up.
You have to remove the cluster, so first you have to take your steering wheel off.
To do that, you first have to remove the airbag, so unplug your batt. Theres two screws that hold the airbag to the wheel, which are size T25 torx bits. Once you remove the airbag, unplug it and set it aside. Then you need to yank the wheel. I believe, if I remember, its a 12 or 13mm socket. Before you take the wheel off, mark where it sits with a marker or something so when you put it back on, its straight.
After you take the wheel off, remove the cluster: The cluster is held to the dash using two T-15 torx bits. Unscrew thoes and pry, carefully, the cluster out of the dash board. Then you need to unclip all the connections. Theres three of them. The way bmw does their connectors is weird, but you have a locking bracket that holds them in place.. you slide that down and they pop out. Once you get the cluster out, you need to disassemble it.
The cluster is held together with 5, t-10 torx bits [marked by the red arrows].
See pic below:
[Mind you, this is an older e36 cluster I borrowed from work for practice, but the m3 cluster is the same. The newer ones have a coding port, which this one is missing]
Back of the cluster
You're going to have to cut the sticker that connects to the blue and black part of the cluster, doing so will void any warrenties. Thats said.. cut the sticker, and gently pull the blue away from the black. Once done, you come to what the pic is below. Now you have to pull the gagues out. They are held on by these supports that rotate to hold the glass in place. Twist them until the glass is free, a closer look and you'll be able to see how its done, they are marked with red arrows:
Gagues inside
Pull them out and it should look like this:
Gagues out
Take the rings, and place them inside, they should have self adheasive. Heres what I learned from doing it. Don't use superglue. Its gets all over the place, and tends to leak where you don't want it. I had to take some rubbing compound from work to get the glue off the clear plastic... that didn't make me happy. I ended up putting a small bit of silicon glue on the backs of them and letting that dry, which helped support them. You can get that at Home Depot. Putting the cluster back together is the oppostie of removal, as is the install back into the car with the wheel and airbag.
If you have more questions, or need more pics, email me.
-Trev
97' M3. '10 R6.
Old Sat, Mar-27-2004, 04:46:55 PM   #16
umnitza
Guest
umnitza's Avatar
that pattern you want is easily achieved one of three ways:
DEPO headlights.
ZKW with modified metal reflector.
ZKW with bixenon projectors.
Old Sat, Mar-27-2004, 04:50:29 PM   #17
Sirius
How many licks..
Sirius's Avatar
Thumbs up
DEPO headlights.
Ahhh thanks. Ill deff keep that in mind
97' M3. '10 R6.
Old Sat, Mar-27-2004, 05:03:34 PM   #18
umnitza
Guest
umnitza's Avatar
one additional noted.
That pattern is actually the stock pattern by all HIDs. --------/--------
The only difference is that the driver's side high beam is a shorter parabola than the passenger side one.
Old Sat, Mar-27-2004, 06:06:35 PM   #19
umnitza
Guest
umnitza's Avatar
we did some fun testing yesterday.
A poorly installed HID, is no better than a wandering eye.
Here's why:
Standard H1
Poorly aimed HID
H1 bulb is brighter
Old Sat, Mar-27-2004, 06:23:28 PM   #20
Sirius
How many licks..
Sirius's Avatar
Ahhh. Very very nice. Ill deff have to get some in the near future.
97' M3. '10 R6.
have u ever regretted getting ellipsoids? TheMensah E36 M3 (1992-1999) 32 Fri, Feb-02-2007 03:29:38 PM
Ellipsoids ICE99M3 E36 M3 (1992-1999) 10 Tue, Apr-12-2005 08:09:32 PM
FING Ellipsoids IIrjII E36 M3 (1992-1999) 16 Fri, Apr-30-2004 04:21:03 AM
FS: Ellipsoids r3drage E36 M3 (1992-1999) 6 Thu, Oct-30-2003 05:21:45 AM
Ellipsoids mike27t E36 M3 (1992-1999) 5 Tue, Sep-02-2003 02:54:08 AM
Discussing Why Ellipsoids are better than US lights:) in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
