Old Sat, May-27-2017, 09:58:37 PM   #11
aznniche
aznniche's Avatar
Default Re: Rod Bearing Comparison
I went with OEM. Surprised the WPC coating wore off in only 15K miles. I'll post pics of my other bearings once I'm completed. Having a rough time angle torqueing (105 degrees) cylinder 3 for whatever reason. It keeps stripping. Cylinder 1 and 6 done, 4 more to go. 8 rod bolts remaining Taking a break so I can reenergize.
Old Sat, May-27-2017, 10:07:06 PM   #12
Originally Posted by aznniche View Post
It keeps stripping.
What?
Old Sat, May-27-2017, 10:07:40 PM   #13
aznniche
aznniche's Avatar
What?
The rod bolt head. If its not on tight, it will deform the bolt and practically make it useless. Oily environment with bad angles attribute to this.
Old Sat, May-27-2017, 10:11:05 PM   #14
Sounds like cheap or ill fitting tools to me. Are you using the correct E-Torx? Just because it fits on there, doesn't mean it is right. A proper sized E-Torx socket should fit TIGHT, not easily go on the head. You're probably one size too big.
Old Sat, May-27-2017, 10:13:40 PM   #15
aznniche
aznniche's Avatar
It's the correct socket, e12, I got cylinders 1 and 6 on without any hitch. 105 degree angle with a 3/8" torque wrench is pretty tough. I just need to find the right position to lay so I can get good leverage without running out of room.
Old Sat, May-27-2017, 10:27:16 PM   #16
csynic
Reputation: 0 csynic is on a distinguished road
so oem rod bearings > wpc bearings?
Jump to top csynic is offline   Reply With Quote
Old Sat, May-27-2017, 10:59:02 PM   #17
FerrisX
Reputation: 0 FerrisX is on a distinguished road
You know what's not hard... a 24 inch breaker bar, 3/8 adapter and an angle torque guage . I'm a manlet if I can do it anyone can.
EDIT: Since most breaker bars swivel down it really helps clearing everyhing while keeping constant motion. I've done it this way on my S54, S62 and S85 something to consider. Also don't set the angle with a torque wrench unless it's a combo deal.
Jump to top FerrisX is offline   Reply With Quote
Old Sat, May-27-2017, 11:14:25 PM   #18
PITT M3 RR
PA
PITT M3 RR's Avatar
Yes and while you want to be as close to spec as possible. Exactly 105 isn't necessary. I believe it was Forbes who tested the bolt stretch, elasticity, procedure, shear etc...use a breaker bar / angle gauge and get close enough.
S54 E36 BUILD
Jump to top PITT M3 RR is online now   Reply With Quote
Old Sat, May-27-2017, 11:17:10 PM   #19
2006E46M3fan
2006E46M3fan's Avatar
This is what I'm now trying to find out.
Jump to top 2006E46M3fan is online now   Reply With Quote
Old Sat, May-27-2017, 11:52:20 PM   #20
aznniche
aznniche's Avatar
I'm using a 3/8" Snap-on TechAngle so it makes life a little bit easier, but the length is only ~17 inches so its a bit tough. But, I was finally successful tightning cylinder #3. I was just laying at a wrong angle and a bit strained. 3 more to go..
Discussing Rod Bearing Comparison in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
