Old Tue, Nov-03-2015, 01:58:14 PM   #41
SliM3
SliM3's Avatar
Default Re: REM (ISF) Microfinished S54 Crankshaft
First off, kudos on the shop wanting every component on there for balancing! I'd think that's a good sign.
Personally, I would wait until you have everything on there. As I said in another thread (to much debate), an inline 6 is a very balanced configuration. *However* the problem comes in when you've got a crank that's reaaally long, and you put a varying load on both ends.. and you run it up to 8,000 rpm
Unlike other engines that aren't balanced internally, there's nothing you need to bolt onto the crank to *balance* it externally, but you do need a damper to keep those oscillations in check. Looking at the graph here, you want to avoid the big, scary sine wave https://en.wikipedia.org/wiki/Fileamping_1.svg from this article https://en.wikipedia.org/wiki/Damping. Since the crankshaft is a constantly moving object under constant stress and strain, you really want to avoid those oscillations. Hence, the thing bolted on the accessory side is a *damper*, not a harmonic *balancer*.. although multiple people vehemently disagreed with that last bit, so I'll leave that grain of salt there. You don't read about snapped cranks too much with an OEM damper in good condition, but I've read about/ heard people who "upgraded" the damper and lost a crankshaft/ engine... I guess that's my really verbose way of saying to make sure the stock damper is used and to not to screw with the damper as long as its in good shape.
Even though the engine is an ideally balanced configuration... you still have the issue of some stuff going up and down while other stuff goes round and round. A normal part of balancing is using precise bob weights for rotating weight and reciprocating weight.. which would be thrown off by going back and reducing the rotating weight later. Something I'm curious about and you might ask them is "overbalancing". Essentially you use a little more than the normal 50% reciprocating weight to make sure the engine is balanced at high RPM.. but not necessarily outside of the desired operating range. If you're going to be racing it and spending the vast majority of the time at 7900 RPM rather than 900, it's supposed to help reduce the higher RPM oscillation/ vibration and save wear on components.
Point being - using a lightweight assembly at one end rather than what the engine was set up for could theoretically make things behave very differently than the stock mass. If you're spending the money to do it right, wait until you can let them do everything right.
Great response, thank you. Steve (machinist) says he balances up to 10,000 rpm, and I want to say 55% of the recip weight. Don't quote me on that figure though.
But yeah you're right, I need to have everything ready to go and not piece-meal later on. Guess I'll start looking at some of the Southbend disc/pressure plate offerings and roll with a new LUK DMF.
Damper is in great shape, BTW.
Old Tue, Nov-03-2015, 02:08:35 PM   #42
paffy
Reputation: 0 paffy is on a distinguished road
Czech_Republic
Awesome info !!
To what level does the dual-mass flywheel effect the damping compared to the rubber damper up front ?
Is it a "system" ?
Do they work independently ?
Do the flywheel springs have more of a detrimental effect on axial vibration?
What happens when you replace the flywheel ?
http://www.msstuning.com/ - serving your MSS5x flashing needs
2014 BMWCCA NY autox E class champion
My GTS4 build journal - http://www.m3forum.net/m3forum/showthread.php?t=551613
Jump to top paffy is offline   Reply With Quote
Old Tue, Nov-03-2015, 02:32:32 PM   #43
Flow
Flow's Avatar
France
I understand maybe 10% of all that you are saying, but it is awesome !
Thank you for sharing and keep us updated on your build.
2004 M3 TiAg / LSB SMG
Old Tue, Nov-03-2015, 02:38:16 PM   #44
Drewster
Drewster's Avatar
Originally Posted by paffy View Post
Awesome info !!
Is it a "system" ?
I'd argue that anything directly attached to the crank makes it behave as part of that mechanical system. Just like a suspension component with specific mass, spring, damping, and torsional characteristics, you can't bolt something on without changing that equation.
I'm honestly not sure what the dynamic response of a dual-mass flywheel would be. Although having the engine balanced for that mass (flywheel springs fully compressed and the whole assembly under constant load) would probably give me enough of a warm/ fuzzy, I would think modeling the dynamic loading is a job for very expensive software.
I read one article online saying that balancing the engine as a whole was "not ideal for race cars" since a change in one component would alter the balance... but my personal argument to that is that replacing a like-for-like component will have less of an effect than adding a whole bunch of mass and damping to an otherwise "known" system. Ideally I would think you would balance the crank, then check everything with the full weight/ assembly for the final desired balance. If you're racing and you lose chunks of your flywheel, engine balance is probably going to be the least of your concerns, anyway. If the engine isn't balanced when fully assembled, what's the point?
Old Tue, Nov-03-2015, 02:52:45 PM   #45
bimmerdriver
Originally Posted by digger View Post
So lets take a stock S54 stock 139mm rod at 8000rpm vs no change other than 150mm rod. i chose 150mm so the differences can be seen
0* and 360* = TDC
180* = BDC
longer rod dwells more at TDC and less at BDC
longer rod has lower peak piston speed
longer rod has lower acceleration at TDC but slighty higher around BDC
longer rod reduces peak rod angularity from 18.1 to 16.9*
Peak piston speed is the same as the crankpin speed for very long rod.
moral of the story is a minor change in rod length doesn't produce vastly different piston motion.
Well done!
Old Tue, Nov-03-2015, 02:56:25 PM   #46
bimmerdriver
Originally Posted by SliM3 View Post
Alright, well since you guys are in physics mode maybe you can answer this question for me:
The machine shop wants every last component that bolts to crankshaft to complete dynamic balancing. I'd like to go with the twin plate clutch from Max PSI, though I really can't squeeze it out of the budget until spring. That being said, if the shop is balancing the crank using the stock DM flywheel, clutch & bolt weights, how severely will I throw off the final balance when I eventually go with the new clutch?
They should be basing their balancing on the assumption the flywheel and pressure plate are already balanced so there won't be any changes if/when you replace them in the future.
Old Tue, Nov-03-2015, 03:02:09 PM   #47
bimmerdriver
Unlike other engines that aren't balanced internally, there shouldn't be anything you need to bolt onto the crank to *balance* it externally, but you do need a damper to keep those oscillations in check. Looking at the graph here, you want to avoid the big, scary sine wave https://en.wikipedia.org/wiki/Fileamping_1.svg from this article https://en.wikipedia.org/wiki/Damping. Since the crankshaft is a constantly moving object under constant stress and strain, you really want to avoid those oscillations. Hence, the thing bolted on the accessory side is a *damper*, not a harmonic *balancer*.. although multiple people vehemently disagreed with that last bit, so I'll leave that grain of salt there. You don't read about snapped cranks too much with an OEM damper in good condition, but I've read about/ heard people who "upgraded" the damper and lost a crankshaft/ engine... I guess that's my really verbose way of saying to make sure the stock damper is used and to not to screw with the damper as long as its in good shape.
Unless there is a very good reason to overbalance, it's much more important to minimize the differences in the balance. It significantly reduces bearing loading at high rpm if the balance is done more precisely.
Old Tue, Nov-03-2015, 03:05:36 PM   #48
bimmerdriver
Great that he balances up to 10000 RPM, but unless you have it on good authority (i.e., someone with experience building 9000 RPM S54 engines) that using 55% of the reciprocating mass instead of the normal 50% is preferable, I'd tread carefully.
Old Tue, Nov-03-2015, 03:27:31 PM   #49
SliM3
SliM3's Avatar
Don't quote me on that 55%. I could be totally off-base with that one.
A longer rod increases the peak force, although your rods aren't that much longer than stock. How does the mass of your piston / rod / bearings compare with stock? Did you consider the Lang Racing approach of going with a wider rod bearing?
Missed your questions from earlier
Stock weight, not including the bearings:
1150 grams
Aftermarket weights, not including bearings (the tool steel wrist pin upgrade added some additional weight as well):
1068 grams
I did consider the wider bearing option, but honestly the cost worked out better with the crank exchange from Lang, the components I have now, and microfinishing.
Plus, I wanted to concentrate more funds on the cylinder head, which is coming up very shortly. Waiting on a quote for the [custom] intake/exhaust multi-angle seat cutter blades from Goodson.
EDIT: Here is the con-rod bolt strengths.
ARP 2000: 190,000 psi yield/220,000 psi tensile
  • 0.006" stretch = 90% of yield = 19,000 lb. clamp-up preload
  • Using Drewster's force estimate of 25.4 kN @ 9000 rpm = 5710 lbs.
  • Safety Margin (cyclic tension load/clamp-up preload) = 166%
SPS-CARR: 260,000 psi yield/310,000 psi tensile
  • 0.006" stretch = 90% of yield = 26,000 lb. clamp-up preload
  • Safety Margin (cyclic tension load/clamp-up preload) = 227%
Old Tue, Nov-03-2015, 03:35:01 PM   #50
Drewster
Drewster's Avatar
Cool. Now I know what rod bolts to use when I refresh my bearings
Just for good measure, I would run the numbers using the actual mass of your rod, pin, and piston using an acceleration of 55k m/s^2 (multiply weight in [kilo]grams to get Newtons).. all I did was use the mass of the stock piston itself to try and put the right amount of trepidation in 'ya
Discussing REM (ISF) Microfinished S54 Crankshaft in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
