Old Mon, Nov-02-2015, 01:03:16 AM   #11
paffy
Reputation: 0 paffy is on a distinguished road
Czech_Republic
Default Re: REM (ISF) Microfinished S54 Crankshaft
Do you have any "before" pics ? The journals show wear marks even after the REM process !?!?
http://www.msstuning.com/ - serving your MSS5x flashing needs
2014 BMWCCA NY autox E class champion
My GTS4 build journal - http://www.m3forum.net/m3forum/showthread.php?t=551613
Jump to top paffy is offline   Reply With Quote
Old Mon, Nov-02-2015, 07:47:38 AM   #12
TheGenius46M
TheGenius46M's Avatar
Looks amazing! Can't wait to see your progress and how your engine is able to handle the increased redline.
2003 E46 M3 TiAg/Cinnamon 6MT
MCS | Recaro | OMP | Hyperco | Besian | AKG | UUC | Rogue | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Status Gruppe |
Old Mon, Nov-02-2015, 11:18:05 AM   #13
SliM3
SliM3's Avatar
Originally Posted by Abad46 View Post
Very nice! Excited to see this progress
Thanks Abad46 Ready to get it done!!
Originally Posted by bimmerdriver View Post
Micropolishing has been proven to reduce windage losses. Presumably you're planning other changes if you intend to run your engine up to 9k RPM, such as rods and valve springs.
Yes, doing a complete build but I don't think I'd run up to 9k on a consistent basis. Redine will be set more in-line with where the 280/272 cams peak, but there are a few guys here I'd like to consult with first. 9k is more like "let's see if it'll do it" type of thing.
Originally Posted by stash1 View Post
Just out of curiosity, how much $$$ did they charge to do that?
stash, I paid $450 for everything, which included a discount. Normally they charge $500 for 6 & 8 crankshafts.
Originally Posted by admranger View Post
Can one assume that if you list one fewer significant figure the number is a zero?
Crank and journals look lovely!
Also, in for pics of transparent aluminum oil pan.
Thanks.. Yeah, those extra digits in the measurements were probably a little unnecessary. I was talking with A. Lang and needed to send him the measurements so I went a little nuts taking them down.
Originally Posted by digger View Post
I would have though you would first bullnose the leading and knife edge the trailing edge of the counterweights if you were concerned about windage and going to get this done. Itís a bit like a brick is never going to have low drag no matter how smooth it is because the geometry is not efficient. skin friction is important but its only one aspect of the resistance
If you are concerned about friction the regular lip seals can be replaced by much better PTFE types if you are spendy enough.
I'd be curious to see this done on an S54 crank. Wouldn't something like that make the crank more difficult to balance, with so much material being removed?
As mentioned earlier, I wanted to take advantage of the anti-wear and oil control improvements in the journal areas. The DFL coated bearings will complete the "package" so to speak.
Actually I do, now that you mention it. I took them while unpacking the crank when it arrived, but I don't think they were very detailed. I look for them.
I think what you're seeing is some streaks of residual oil after I wiped the journals down for the pics. I didn't want to solvent wipe them just yet, as the surface will oxidize pretty quickly if left unprotected.
Thanks man. Yeah that 9k redline will most likely be a one-time deal for me. Probably keep a it at a more conservative 8500.
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Mon, Nov-02-2015, 05:02:36 PM   #14
bimmerdriver
There is a discussion about balancing raging in another thread. If anything, on top of rods and valvesprings, balancing is probably the most important thing for you to consider if you're planning to run your engine to 9k. Please keep posting updates about your build.
Old Mon, Nov-02-2015, 05:19:23 PM   #15
sergbaja5t
Uncle Grandpa
sergbaja5t's Avatar
Reputation: 0 sergbaja5t is on a distinguished road
I have got some Nutty bars and going to watch this build! Good work!
2016 Ford F150 Screw sport Egoboost
2005 SilberGrau Met/Schwarz M3 Smg, VMR 703 reps, Megan Racing sec 3, Bilstein PSS10/Koni
2002 StahlGrau MET/Schwarz M3 6spd AA headers, Supersprint x-pipe, AA Gen 4 sec3, Besian hub and seals, Turbotoy hardware, Rouge Engineering Vanos & Coolant pipe, Arp studded, H&R/ST/Bilstein coilovers, M220 19's. S54 timing tool w/ two guide pins**FOR RENT** Atlanta valve adjustment service(ask about rates)! Simple coding & DME scanning (Atlanta area)
Jump to top sergbaja5t is offline   Reply With Quote
Old Mon, Nov-02-2015, 05:39:56 PM   #16
Banang0
Few Dollars; Less Sense.
Banang0's Avatar
Reputation: 0 Banang0 is on a distinguished road
United Kingdom
Lovely. Interested in seeing more.
2002 M3, mildly enhanced
2005 M3 ZCP, much as it left the factory
2006 E86 M
2015 GT3
Jump to top Banang0 is offline   Reply With Quote
Old Mon, Nov-02-2015, 05:45:02 PM   #17
Drewster
Drewster's Avatar
Almost a year ago, I started looking into the specs on the S54 to say "okay, if X wasn't a weak point, what could you get out of the S54?"
http://www.m3forum.net/m3forum/showthread.php?t=497248
The first thing you need to look at when you start talking about screaming to 9,000 RPM is what kind of force does that put on the piston? The stroke length and RPM have an immediate affect.
You can spitball an ideal rev limit by using:
RPM = (desiredPistonSpeed * 6)/ stroke
To get an idea of the amount of force you're putting on the internals, you can calculate the amount of acceleration you'll be calling for your piston to do with:
(RPM^2 * stroke / 2189) * 1.333
^And note that's RPM SQUARED! In other words, the forces going from 8000 to 9000 RPM are massively greater than the forces between 7000 and 8000
The normally accepted limit is 150 k ft/s^2 - depending on the material used. The higher you go, you can see the acceleration is enough to literally rip the pin out of the bottom of the piston.
As I noted in that thread a year ago, even if you beef up the rod, piston and crank, even if you beef up the valvesprings to prevent valve float... F1 engines don't like to go far beyond 5,000 feet/ minute mean piston speed for a reason. It turns out that once you exceed 5,500 fpm, it's actually nearly impossible to keep a film of oil lubricating the cylinder wall.
Old Mon, Nov-02-2015, 06:34:02 PM   #18
SliM3
SliM3's Avatar
Here is the piston/rod combo. The skirts & ring lands are coated with tungsten/moly DFL, and the rings & cylinder bores will be treated with tungsten disulfide just prior to assembly. I also opted for upgraded tool steel wrist pins, and the rods are actually slightly longer than stock so rod:stroke ratio changes by a small amount (1.52 to 1.54).
I'm also swapping-out the ARP 2000 rod bolts for a set of SPS-CARR Multiphase bolts, same kind used in the Sprint Cup motors turning 9800+ continuous rpm.
I'd say the rotating assembly will be bulletproof and oil control to the piston skirts vastly improved since the DFL has fluid retention properties. Needless to say, 9000 is nothing I'm looking to continuously run, just wanna see if the engine can pull it off. I'll probably "chicken s**t" out though!!
In all seriousness, redline will be set based on what the cams tell me.
Old Mon, Nov-02-2015, 06:44:10 PM   #19
Drewster
Drewster's Avatar
Just running the numbers, you'll cross that "accepted limit" at ~8273 RPM.
By 8500 RPM, you're at ~158,428 ft/s^2. If you give it a jab to rev up to 9,000 RPM, you're at 177,615 ft/s^2, so about 18% over the accepted limits, and almost 27% over the forces at stock redline.
Looking at it another way, with stock 470g pistons, 9,000 RPM puts 25.4 kN of force between the wrist pin and the crank.. by my napkin math that's enough to stretch most rod bolts a decent amount, if not break them. If you hold it there for just one second, you just slammed each piston with that force 150 times.
Bear in mind this is spitballing pure *force*, not even friction, heat, etc.
[EDIT]
In all seriousness, redline should primarily be based on what the piston is rated for, and stroke is what says how much force will be placed on the piston during a revolution by the crank, not the ratio.. and that's neglecting if you'll have higher cylinder pressures with longer rods. I'd be curious what the engine can do as well, but I would be seriously concerned about a quick experiment ending up a very expensive and explosive mistake. Not to mention that even *if* the engine can take that RPM, there's no guarantee that the clutch disk and other driveline components can. I watched a video of a Corvette running NASA TT money shift, overrev, and the clutch actually decimated his oil and fuel lines.. which burned the car to a crisp. Your car, of course... but be very careful
Old Mon, Nov-02-2015, 06:49:59 PM   #20
bimmerdriver
A longer rod increases the peak force, although your rods aren't that much longer than stock. How does the mass of your piston / rod / bearings compare with stock? Did you consider the Lang Racing approach of going with a wider rod bearing?
Discussing REM (ISF) Microfinished S54 Crankshaft in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
