Old Fri, May-26-2017, 10:39:43 PM   #11
FerrisX
Reputation: 0 FerrisX is on a distinguished road
Default Re: New clutch installed...loud constant squeeling Sounds??
Sorry didnt see if you went stock or aftermarket. Either open her back up and post pics
Sent from my SAMSUNG-SM-G900A using Tapatalk
Jump to top FerrisX is offline   Reply With Quote
Old Fri, May-26-2017, 11:14:00 PM   #12
T3AMFiSh
Your mom goes to college
T3AMFiSh's Avatar
Reputation: 0 T3AMFiSh is on a distinguished road
So replaced a sprung hub with a non-sprung hub?? your squeal is vibration, you should have got a sprung hub, also the plate needs to be oriented correctly. There is a face side (towards the pressure plate) and a back side towards the flywheel.
Also I hope you greased the input shaft with white lithium grease, as well the pilot bearing and pivot arm
Jump to top T3AMFiSh is offline   Reply With Quote
Old Sat, May-27-2017, 12:51:00 AM   #13
Em trizzle
Reputation: 0 Em trizzle is on a distinguished road
No I went with a sprung hub ^^
02 m3 ac schnitzer front strut towers brace..knn short ram air intake..front eye lid cover..ac schnitzer rear trunk lip..fx racing stage 2 clutch/lightweight 14lb flywheel..Redish rear subframe reinforcement kit..75d rear subframe bushings..solid aluminum diff bushings..h&r 1.5" lowering Springs..limo tint..tws 19" rims..gutted trunk..reinforment rtab bracket welding
Jump to top Em trizzle is offline   Reply With Quote
Old Sun, May-28-2017, 12:41:06 PM   #14
Em trizzle
Ok so I took it apart and the center flange with the springs on the clutch disc are wrong way, touching the shaft the throw out bearing is on..this is crazy because the instructions that came with this kit had a diagram which showed this orientation to be correct.
Discussing New clutch installed...loud constant squeeling Sounds?? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
