Old Wed, Dec-10-2014, 01:40:16 PM   #41
DodgeStratus
DodgeStratus's Avatar
Reputation: 0 DodgeStratus is on a distinguished road
Default Re: Help diagnosing 2003 E46 M3 engine ticking noise?
Originally Posted by SteveEvans View Post
When Mr Vanos in the UK looked at my cams he commented that they were shiny; they should be slightly dark due to the surface hardening. That had clearly worn off.
Steve
The lobe will naturally be worn shiny and smooth. This is not abnormal. If the non lobe portion of the cam is shiny then the valves have been let go too far out of spec. The best I understand it is both the cam lobes and the followers come with this treatment and they are meant to wear in together at the same time.
Originally Posted by eimkeith View Post
yeah, mine are shiny and scored, and my clearances change with the angle of the feeler blade (suggesting flattened follower profiles, I'd think.)
I suppose I'm looking for a cam/follower set now. :/
Possibly... hard to say without removing. Even without flat spots there will be on optimum angle of attack with which to use the feelers.
Jump to top DodgeStratus is offline   Reply With Quote
Old Mon, Feb-22-2016, 02:29:37 AM   #42
Rx7thHeaven
Reputation: 0 Rx7thHeaven is on a distinguished road
Bringing this one back from the dead... I have the same noise and have adjusted the valves twice. I have checked all my followers but mainly concentrated on the pivot point on the shaft looking for sloppiness... I didn't spend a lot of time inspecting the foot of the follower. I did however look the cams over fairly well and didn't notice any abnormal wear... I am suspecting cam followers but would like to know if the OP has gotten to the bottom of this because this video is the EXACT noise my car makes.
Thanks,
Jonathan
Jump to top Rx7thHeaven is offline   Reply With Quote
Old Mon, Feb-22-2016, 05:09:35 AM   #43
Rajaie
Reputation: 0 Rajaie is on a distinguished road
A loose sparkplug causes a similar noise.
Jump to top Rajaie is offline   Reply With Quote
Old Mon, Feb-22-2016, 06:02:15 AM   #44
HassanEido
HassanEido's Avatar
Lebanon
just change the bad follower..smfh ... talk about epic over kill.
Old Wed, Mar-02-2016, 01:12:08 PM   #45
eimkeith
eimkeith's Avatar
Reputation: 0 eimkeith is on a distinguished road
I'd assume same mileage/operating conditions for all of the followers; why change one to have the others fail shortly thereafter when the labor delta between changing one and all is insignificant?
Sounds like false economy to me, professionally speaking...
keith.
(sent from my rotary dial phone.)
keith
'72 911, '67 M715, '03 M3
'70 TD2B, '73 CB750
www.zuffenhaus.us
Jump to top eimkeith is offline   Reply With Quote
Old Wed, Mar-02-2016, 01:23:46 PM   #46
akagc
Reputation: 0 akagc is on a distinguished road
Interested in a definite answer to this if anyone has pin pointed it. I have 67k miles on the clock, but I do not have that issue, however, some people say it's common so I'd like to be prepared if I ever hear this. Thanks.
- 04 Silver (tiag) ZHP 330i
- 06 Silver Grey ZCP M3
- 02 Black Civic. Beater
Jump to top akagc is offline   Reply With Quote
Old Wed, Mar-02-2016, 01:28:31 PM   #47
zerotosixty
Search Nazi
zerotosixty's Avatar
Reputation: 0 zerotosixty is on a distinguished road
Another one here with same noise. Even after a proper\thorough valve adjustment. Its normal.
Lords of M3Forum official member
ZeroToSixty's car journal
Originally Posted by Why m3 View Post
Not everybody Is into tracking because you guys other to each of their own
Originally Posted by cowboyM3 View Post
Again, just like several of you have proved and myself: it's going to be nothing but a $hitshow until our science is to the height to which we can prove something's there and the time it gets there.
Until then, we must prevent these mistaken pregnancies in the first place
Jump to top zerotosixty is offline   Reply With Quote
Old Wed, Mar-02-2016, 01:58:07 PM   #48
eimkeith
eimkeith's Avatar
After I replaced my followers my specific ticking noise disappeared (as would be expected.)
Engine is quiet with a subtle, even, regular, mechanical top end noise (not unlike my Ducati)
If you can isolate the ticking to one specific area of the valve cover, I'd say that isn't normal top end noise.
If valve adjustment doesn't correct it, it may well be a flattened cam follower.
keith.
keith
'70 TD2B, '73 CB750
www.zuffenhaus.us
Old Wed, Mar-02-2016, 02:51:41 PM   #49
bmeyer
bmeyer's Avatar
Reputation: 0 bmeyer has disabled reputation
Can you tell if it's coming more from the front or the back of the engine? Can you put the front of the car up on jack stands and listen from underneath?
It's definitely not normal for the car to sound that say and it sounds too low pitched to be out of spec valves.
'06 ///M3 Coupe
Jump to top bmeyer is offline   Reply With Quote
Old Sat, Mar-12-2016, 03:10:00 AM   #50
ftc3
Reputation: 0 ftc3 is on a distinguished road
Same here. I had a nasty tick that adjusting the valves couldn't fix. I swapped cams for Schrick and replaced my followers at the same time. The ticking noise is gone.
keith.
My journal
Dinan Intake | Dinan TBs | Schrick 280/272 | SSV1| SS Res Sec 2 | Dinan Exhaust | Koni Yellow | Dinan Springs | TTFS Tune | 356WHP
Jump to top ftc3 is offline   Reply With Quote
e46, e46m3, engine, s54, vanos
Discussing Help diagnosing 2003 E46 M3 engine ticking noise? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
