Old Sat, Jan-12-2019, 05:03:12 PM   #1
John Evans
Reputation: 0 John Evans is on a distinguished road
Arrow Will 18" Style 67 work with Brembo 6P 355mm?
Per the title, will the 18" Style 67 work with Brembo 6P 355mm?
I'm assuming I'd have to run the rears up front and a 5-15mm spacer, but I just want to make sure the barrel would clear it. I can't find any pictures or anything under search on this so regretfully I'm making this thread.
Also I don't have the 18" wheels yet but would want someones first hand experience before picking up a square setup.
Thank you!
Jump to top John Evans is offline   Reply With Quote
Old Sat, Jan-12-2019, 05:10:03 PM   #2
Mike RT4
Reputation: 0 Mike RT4 is on a distinguished road
United Kingdom
Default Re: Will 18" Style 67 work with Brembo 6P 355mm?
They clear the AP CP5575 6-pots with a 356mm disc without a spacer, so I imagine a set of 12mm / 15mm spacers would give all the clearance required .
CSL No 44 - AP 5575 6-pots front, PF 356 x 32 discs, RS 29 pads / AP 5144 4-pots rear, RS 29 pads - Castrol SRF / Supersprint full system from headers back, inc race cats with "Race" backbox / H&R coilovers / Turner Motorsport RTAB limiter kit
Jump to top Mike RT4 is offline   Reply With Quote
Old Sat, Jan-12-2019, 05:11:15 PM   #3
John Evans
Thank you so much for the info Mike! Greatly appreciated
67m, 6pot, brembo, style 67
Discussing Will 18" Style 67 work with Brembo 6P 355mm? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
