Old Sat, Jan-12-2019, 02:49:52 AM   #1
TramRam
TramRam
TramRam's Avatar
Reputation: 0 TramRam is on a distinguished road
Default Oil Filter Housing Flush Post Spun Conn Rod Brg
As part of my engine cleanup following a spun connecting rod bearing, I'm interested in flushing out my oil filter housing. I wiped out a lot of bearing flakes from mine under the filter with lots in my oil pan & based on what I saw, there HAS TO be more of the same crap in passageways in that thing that I'd like to flush it out but I don't know what's what as far as the caps, screws and plugs on the unit. Many ppl replace their oil cooler (which is fed & takes oil from the housing), so it seems to me that it's pretty critical to flush this thing too! Has anyone done this and/or know where to get a flow diagram of this part? Obviously, if all else fails, just getting fluids in and out of it is better than doing nothing & it may indicate what opening leads where but I don't want to get the flow directions backwards if I don't have to. Thanks in advance!
Help to Reduce Road Rage - Keep the Left Lane Clear for Faster Moving Traffic
Jump to top TramRam is offline   Reply With Quote
Old Sat, Jan-12-2019, 05:01:18 PM   #2
M clunk
M clunk's Avatar
Reputation: 0 M clunk is on a distinguished road
Default Re: Oil Filter Housing Flush Post Spun Conn Rod Brg
Take you vanos apart, and clean it, also.
I just did it on a motor that spun a bearing. That crap was everywhere in there.
My race car build thread
Jump to top M clunk is offline   Reply With Quote
Old Sun, Jan-13-2019, 03:21:32 PM   #3
TramRam
TramRam
TramRam's Avatar
DONE! Thanks & good luck to you
Discussing Oil Filter Housing Flush Post Spun Conn Rod Brg in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
