Old Fri, Jan-11-2019, 08:36:24 PM   #1
Boss77
Boss77's Avatar
Reputation: 0 Boss77 is on a distinguished road
Default Wheel Rubbing - Suggestions?
I have a 2004 M3 Vert with what I think are 19 inch Miro 111s. I just had the front and rear suspension/shocks rebuilt with stock parts and have new tires, but am still getting rubbing at low speeds at one or more of the wheels.
BMW OEM spec was 225/40/19 Front and 255/35/19 Rear. Miro's site I see says it should have 245/35/19 Front and 275/30/19 Rear. Does anyone know if this is causing my rubbing or should I check to see if the spacers are right (+35 Front and +20 Rear)?
Jump to top Boss77 is offline   Reply With Quote
Old Fri, Jan-11-2019, 08:37:03 PM   #2
mdavidm3
Reputation: 0 mdavidm3 is on a distinguished road
Default Re: Wheel Rubbing - Suggestions?
You need an alignment
AKG||Euro Headers||Customized Bimmerworld Race Exhaust||Tilton Twin Disk Clutch||RTD||Mishimoto||Kirk Rollbar||Schroth||Sparco||Momo||OMP||Ground Control||Eibach||JRZ RSpro (rear coilover)||PFC Z31 BBK||G-Loc Brakes||Enkei NT03||Nitto NT01||Custom Chassis Mounted Splitter||AJ Hartman Wing||TTFS Tune||2800 lbs
Trackspec Autosports
MMI Vehicle Systems
Ravenol
G-loc Brakes
IG: marcdavid.m3
Jump to top mdavidm3 is offline   Reply With Quote
Old Fri, Jan-11-2019, 09:58:11 PM   #3
Boss77
Boss77's Avatar
Thanks - I have gotten an alignment. To be clear - I am only getting rubbing at full turn at low speed. Any thoughts?
Old Sat, Jan-12-2019, 12:35:07 AM   #4
mrgizmo04
mrgizmo04's Avatar
Have you checked the plastic inner fender liner? Clips popped off or it is warped from age?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Jan-12-2019, 09:08:53 PM   #5
scootter82
Reputation: 0 scootter82 is on a distinguished road
05 Vert owner w/19" rims here. Is it the rear that rubs? If so, I highly suspect that it is your diff, and not your wheels rubbing. I had the same experience. Turns out there is a service bulletin advisory to replace the rear diff fluid with an updated version that had better friction additives, or something. After that was done on mine, the "rubbing" noise went away completely.
Jump to top scootter82 is offline   Reply With Quote
Discussing Wheel Rubbing - Suggestions? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
