Old Fri, Jan-11-2019, 07:09:52 PM   #11
Bimmerchop
Reputation: 0 Bimmerchop is on a distinguished road
Default Re: Apex Wheel Fitment question
I've had a square set of et35 and now et22 ARC8s on 265/25 PSSs. Play around with the camber, but depending on how low you are you might still need to roll your fenders and quarters a bit. For what it's worth, here's a picture of the current setup; -2.5F/-2.7R with a 10mm spacer back there.
Rich | Flickr | Instagram | My AW/IR E46 M3 Journal
- AW/IR 6MT E46 M3
- JB/B 5MT E46 328i
- Ibis/Alcantara B8.5 A4 S-line
- Pearl Stg3+ B5 S4 (sold)
EURO.techniks
Jump to top Bimmerchop is offline   Reply With Quote
Old Fri, Jan-11-2019, 07:40:03 PM   #12
Engrmikl
Reputation: 0 Engrmikl is on a distinguished road
Yeh not up for rolled fenders. The guy selling them was lowered with around -3 up front and says he didnt have any issues.
Jump to top Engrmikl is offline   Reply With Quote
Old Sat, Jan-12-2019, 12:25:37 AM   #13
bigjae1976
Default Apex Wheel Fitment question
I wanna say you don’t have to run a ridiculous amount of neg camber if don’t roll your fenders with 9.5” wheels.
Fender rolling is a necessity with 10” wheels.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sat, Jan-12-2019, 03:41:19 PM   #14
speedblind_az
Reputation: 0 speedblind_az is on a distinguished road
I ran 18” ARCs with 35 mm offset and 265s on my last car. No camber plates and no rolling. Suspension was Eibach Pro Street S at the recommended height. Spacer in the rear but that’s it. Great setup.
Jump to top speedblind_az is offline   Reply With Quote
Old Mon, Jan-14-2019, 12:36:18 PM   #15
Engrmikl
I put one of these on the front of my car Sunday. They stick out pretty far. I actually had clearance and no rubbing with the car just sitting there with -2 camber. I have mixed feeling about that look.
Old Mon, Jan-14-2019, 12:55:50 PM   #16
.'s Avatar
Reputation: 0 . is on a distinguished road
Mexiflush yo
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, Paul Claude tune, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5” twin-piped resonated section 2, SGT scza section 3.
Drivetrain: Clutch Masters FX725, Clutch Masters Hydraulic TB, RTD V2 mini shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Bilstein PSS9's, RE RSM's, UUC sway bars, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware 75mm stud kit.
Interior: Cobra Nogaro seats, BMW Performance shift knob/e-brake/pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is offline   Reply With Quote
Old Mon, Jan-14-2019, 05:47:08 PM   #17
Metro81
Reputation: 0 Metro81 is on a distinguished road
Do PSS-9 have linear or progressive spring? I have KW V2, progressive spring so my APEX EC-7 et35 would touch the upper part of the spring. As a result I ran a 12mm spacer and w MPSS 265/35 I would have a very minor amount of rub, but only at the track. Otherwise no rubbing on the fender. I would expect that if you have no clearance issues with the spring on the inside then you shouldn’t have any rubbing concerns on the fender if you aren’t running a spacer.
TTFS | CPI | RE | APEX | PFC | KW | GC | BimmerWorld | Hard Motorsports | Status Gruppe | n15DESIGN | RaceWerks
Jump to top Metro81 is offline   Reply With Quote
Old Mon, Jan-14-2019, 05:58:51 PM   #18
bigjae1976
Not the best look since the bottom outside of the tire will stick out. And the front track width will be wider with a square wheel setup. A 12mm spacer makes the track widths about equal on my E90 M3...probably similar on an E46.
Old Tue, Jan-15-2019, 12:18:53 PM   #19
Engrmikl
I passed on them. To many concerns and issues to worry about. Going to keep looking for a set of et35s.
Discussing Apex Wheel Fitment question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
