Old Fri, Jan-11-2019, 05:05:35 PM   #1
Engrmikl
Reputation: 0 Engrmikl is on a distinguished road
Default Apex Wheel Fitment question
Hi All
Looking at a set of 18x9.5 et22s with 265/35 from a fellow member and have conerns about fitment. Is anyone running this size ET? How would I set the car up for them to work for both track and street without having problems of rubbing and a bunch of camber?
I am running Bilstien PSS10s with 19s now(Dont know the offset) lowered to the top of the tire with no rubbing.
Jump to top Engrmikl is offline   Reply With Quote
Old Fri, Jan-11-2019, 05:14:30 PM   #2
bigjae1976
Default Re: Apex Wheel Fitment question
Youíre gonna need camber to run those tires. If I have to make a guess between -2 and -3. Probably closer to -2.
I have to run at least -3.5 with 275 Nitto NT01s with the fenders flattened, not just rolled.
The tire brand and model will also make a big difference.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Fri, Jan-11-2019, 06:03:26 PM   #3
Engrmikl
I am would be running Mich Pilot Sports for now then maybe a full track slick of some sort
I am running -2 camber now.
Using the ET35 would be better then correct?
Thanks
Old Fri, Jan-11-2019, 06:13:20 PM   #4
bigjae1976
An ET35 wheel would be safer. You can always add a spacer but you canít change the offset from +22 to +35.
Old Fri, Jan-11-2019, 06:26:14 PM   #5
Engrmikl
Thanks
Its price seems pretty good. $1500 in really good shape, ceramic coated and a set of Mich PSS with 5k miles. They are on our for sale section
Old Fri, Jan-11-2019, 06:31:19 PM   #6
bigjae1976
Originally Posted by Engrmikl View Post
Thanks
Thatís not bad. I donít value used tires very much. 5k miles is about 25-33% of their useful life.
Old Fri, Jan-11-2019, 06:39:50 PM   #7
Engrmikl
I agree on the tires but an extra $150 for four of them I could run them a few track days. They guy is also 15 mins from my house.
Old Fri, Jan-11-2019, 06:39:56 PM   #8
Gary Powers
Taking the long way home.
Gary Powers's Avatar
Reputation: 0 Gary Powers is on a distinguished road
Im running the 18x9.5 et22s with 255/35s and -2 degrees of camber in front with no spacer. I havent measured my ride height but im on eibach prokit springs with koni yellows. Ride height is probably an inch or so below stock and I have no rubbing whatsoever except for a small bit at full lock
'03 E46 M3
Jump to top Gary Powers is offline   Reply With Quote
Old Fri, Jan-11-2019, 07:13:55 PM   #9
Engrmikl
I have a good reason to want the 265/35 tires. My engine builder uses that size on the race cars. I can get his hand me down(i think he runs Hoosier) with three or less heat cycles for pretty cheap.
Old Fri, Jan-11-2019, 07:43:16 PM   #10
M3AZ
///M3AZ
Reputation: 0 M3AZ has disabled reputation
You shouldn’t have any problems. I run same wheels at ET35 with 15mm spacers, and no rubbing at all.
Jump to top M3AZ is online now   Reply With Quote
Discussing Apex Wheel Fitment question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
