Old Wed, Jan-09-2019, 08:40:42 AM   #1
berto
Reputation: 0 berto is on a distinguished road
Default Help please, smg wont display, crank but no start
hi guys, i recently changed headers on my 03 and put everything back in place reconnected the battery and tried to start her up, the gear display on the dash is not showing any numbers she cracks but does not fire up. i checked all the wires and the engine ground to chassis all is connected, checked fuses and relays all is well fuel pump primes SMG pump primes but no start. searched most threads cant seem to find an answer. i have owned this car for almost 11 years now faced almost all m3 issues but this is a first.
also and this is weird but its cranking without needing to press on the breaks.
Jump to top berto is offline   Reply With Quote
Old Wed, Jan-09-2019, 02:21:26 PM   #2
atsantone
Reputation: 0 atsantone is on a distinguished road
Default Re: Help please, smg wont display, crank but no start
Hard to say what happened here, but, start with the easy stuff first. Check and
Clear codes then perform a dme/ews alignment(even though it cranks..).
Any codes that reappear will likely be the culprits.
Anthony
Jump to top atsantone is online now   Reply With Quote
Old Wed, Jan-09-2019, 05:53:11 PM   #3
Mr.wReckless
Mr.wReckless's Avatar
Reputation: 0 Mr.wReckless is on a distinguished road
Norway
Following as I am changing headers too ATM. I have noticed I haven’t got a gear display either but I’ve got the salmon relay pulled to save battery from unneccessary priming whilst I work on the car during winter storage.
Out of curiousness, have you checked the fuel pump fuse in the glove compartment?
Regards
Jump to top Mr.wReckless is offline   Reply With Quote
Old Fri, Jan-11-2019, 05:19:34 PM   #4
berto
Thx Anthony, i couldnt get my ha ds on a diagnostic tool yet ill scan and check the codes
Old Fri, Jan-11-2019, 05:23:37 PM   #5
berto
Originally Posted by Mr.wReckless View Post
Following as I am changing headers too ATM. I have noticed I havenít got a gear display either but Iíve got the salmon relay pulled to save battery from unneccessary priming whilst I work on the car during winter storage.
Regards
I tried my backup salmon relay ... nothing same issue no numbers on the display
So its not that. Checked the fuel pump fuse its good fuel pump primes just fine.
Its driving me crazy, mayb its in safe mode or something i dont know i guess i need to scan it and see.
Old Fri, Jan-11-2019, 05:31:22 PM   #6
Texaz3
Do you hear smg pump prime when you open the door?
Old Fri, Jan-11-2019, 05:32:56 PM   #7
Mr.wReckless
Norway
I hear a lot of talk about GPS (gear position sensor), could a compete faulty sensor, or perhaps disconnected one be the culprit of a "no gear display" symptom?
Other suggestions would be hood latch sensors, as well as I suspect the brake pedal has to be pressed for the SMG to change into neutral so perhaps a potential fault there too?
Just spitballin' scapegoats here, but they may herd somewhere else AFAIK.
Regards
Old Fri, Jan-11-2019, 05:33:37 PM   #8
Mr.wReckless
Norway
In the OP he says it does.
Regards
Old Sat, Jan-12-2019, 08:21:53 AM   #9
berto
Post Re: Help please, smg wont display, crank but no start
Regards
i dont think its the hood latch we are not there yet i just need her to start first
it could be the GPS, but its engaging gears fine i can hear it from under the car. could it be some kind of safe mode i dont know about ???
i mean it cranks fine all pumps prime all is well if i shit the gear nob to first or put it in reverse it wont crank until i shift back to neutral which means the gears are engaging fine...
Old Sat, Jan-12-2019, 04:47:11 PM   #10
Pnick
Pnick's Avatar
Cranking but no start is not related to SMG. If you have SMG issues, it will not crank at all.
Look for no start issues somewhere else...maybe related to the header replacement (any ground wire/s you disconnected in the engine bay?).
Fuel, Spark, Compression all when properly timed = start?.
Jump to top Pnick is online now   Reply With Quote
Discussing Help please, smg wont display, crank but no start in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
