Old Thu, Jan-10-2019, 02:48:12 PM   #31
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
Default Re: What dampers should i buy
ive been debating shopping for new dampers and just pledged for the JRZ group buy... Going with RS1 because I simply don't need more than that and a good damper is worth the money..
I've had so many different suspension set ups and I want that One and done set up.
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@_Frank_Stone_
Jump to top OneFastSicilian is offline   Reply With Quote
Old Fri, Jan-11-2019, 11:05:20 PM   #32
Jaredomin
Jaredomin's Avatar
Reputation: 0 Jaredomin is on a distinguished road
Any one try kw competitions?
Jump to top Jaredomin is offline   Reply With Quote
Old Sat, Jan-12-2019, 02:21:26 PM   #33
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Originally Posted by Kwakjoe View Post
Unsure. I’d ballpark around 3400-3800 with all hardware etc.
I will echo the same sentiment as everyone else though. The best way to advance as a driver is to do as much as you can with as little as possible.
While that is true, blown garbage suspension is counter productive and anything spent on a interim measure is ultimately wasted money.
911 Journal/Build Thread
Old Sat, Jan-12-2019, 02:25:24 PM   #34
eacmen
OP. I would read through the Flat Ride thread from FCM (http://www.m3forum.net/m3forum/showthread.php?t=601913) and watch his youtube videos. There is some very valuable info in that thread and in his videos. Some agree with his methods and some don't, he has me seriously re-considering what spring rates to run.
I ran PSS9 (similar to PSS10) on street and track for a couple years and loved them. The front drivers strut started leaking and I didn't have time for a rebuild so I bought some JRZs.
If you have time for a project to rebuild the front struts I am selling the PSS9 kit for real cheap, can use the money saved on seat time. PM me if interested.
Jump to top eacmen is offline   Reply With Quote
Old Sat, Jan-12-2019, 04:15:19 PM   #35
Jaredomin
Jaredomin's Avatar
What would you consider interim
Ive been subd to it since the first post.
He is undoubtedly a very smart man when it comes to damping and dynamics.
Im starting to like the kw comps. I think theres alot of value to be had for 3k with them. Interested to see if anyone has ran these before.
Old Sat, Jan-12-2019, 05:42:41 PM   #36
I'm running 300/550 and it's miles better than 440/550 was. You don't have to believe in flat ride, but you at least should be aware that this car's rates, stock, are 143lb front and a very progressive 350-600 rear (forgot exact #s, but something like that).
Why only increase the front rates with aftermarket coilovers like 500/600? Makes no sense to me.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · WPC'd OE bearings · oil catch can · fan/SAP/washer delete · CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/600) + tall RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Sat, Jan-12-2019, 10:05:58 PM   #37
mrgizmo04
mrgizmo04's Avatar
T, I think there are 2 problems overall. 1) The industry does not valve aftermarket shocks per Shaikh's flat ride methodology and tries to cater more toward sportier/dual duty/track use cases (per Shaikh this is mostly marketing that stiffer is better), which require stiffer springs to work with the valving produced. 2) Dropping front spring rates creates a few issues with improperly valved/matched shocks for those who hit the track, to the point that you have to start really figuring things out in terms of wheel fitment/bottoming/scraping, raising the ride height, increasing spring preload, etc for when you slam the brakes and dive into corners at 100mph and ride on bump stops, even without aero.
You simply cant take a shock valved for a 500 or 600 spring and drop a 300 or 400 spring rate on it and expect amazingness. Sure on the street it might feel good and give you a flat ride, but the setup starts falling apart a bit when you start pushing it. I'm especially running into some trouble with Ohlins with this methodology since spring preload and ride height are the same adjustment and Ohlins shocks already have limited travel as it is.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Jan-12-2019, 11:01:32 PM   #38
Jaredomin
Jaredomin's Avatar
Originally Posted by mrgizmo04 View Post
T,
If you buy sht dampers that may be the case
Everything in suspension is a compromise.
A jack of all trades is a master of none!!
“Dual duty”=
Old Sat, Jan-12-2019, 11:21:58 PM   #39
mrgizmo04
mrgizmo04's Avatar
“Dual duty”=
I dont think it has to do with sht dampers and more to do with a range of oscillation frequencies that can be paired with a certain spring rate.
Even high end MCS and JRZ need to be revalved/rebuilt to run spring rates that are drastically different than what comes with them originally. Some will take about +/- 20% spring rate difference, after that shocks need to be re-optimized for a different set of frequencies.
'05 M3 6MT coupe
Old Sat, Jan-12-2019, 11:30:45 PM   #40
I didn't say anthing about dampers, just spring rates in relation to the flatride stuff.
Why triple or quad the front rates, but then barely increase the rear rates 110-150% ?
_
Discussing What dampers should i buy in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
