Old Wed, Jan-09-2019, 10:28:25 PM   #21
Jaredomin
Jaredomin's Avatar
Reputation: 0 Jaredomin is on a distinguished road
Default Re: What dampers should i buy
Originally Posted by Mike RT4 View Post
Read through the Flat Ride thread and then hit ShaikhA up for some custom valved H & R fixed rate dampers.....
Yea his theories are interesting but not something im interested in.
Jump to top Jaredomin is online now   Reply With Quote
Old Wed, Jan-09-2019, 10:59:05 PM   #22
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Default What dampers should i buy
Iím planning to go with double adjustable ground controls with their hybrid camber plates and adjustable weight jacks. I think that runs around $3k.
Not sure if GC has fallen out of favor but they used to be regarded as a great bang for buck coilover for our platform
Jump to top Blaikenstein is offline   Reply With Quote
Old Wed, Jan-09-2019, 11:03:22 PM   #23
Math and physics don't interest you? I'm surprised.
_
Old Wed, Jan-09-2019, 11:11:35 PM   #24
Jaredomin
Jaredomin's Avatar
Hey man if you want to take turns at full tilt with some billy hds by all means.
I can match frequencies with out using less damping. But again if you want to follow overvalved conspiracy theroies god bless you, Ill follow the podium.
Give this one a read...im sure youre a reading man
Old Thu, Jan-10-2019, 12:35:11 AM   #25
twentyseven
@itsmejonnyv
twentyseven's Avatar
@27 interesting suggestion w the pss10. I think you see what predicement im in here.
Everything feels like a compromise or not what im looking for or too much $ for what im getting. I agree with the first comment regarding higher end dampers w/o cans. Based on some other threads regarding jrz/mcs the one thing ive noticed is everyone ends up wanting cans later on.
Yup.. I know your predicament because i've been down this road and owned just about every setup you are considering.
PSS10 aren't fancy but they will work really well for how you plan to use them. It's the best damper for the money IMO. The Ohlins are a small set up, but spending the difference on sways, corner balancing, fresh moving parts etc will benefit you on track FAR more in the long run. Add some 550/700 springs and Hotchkis bars and you will have an absolute beast of a car on your hands that will take years of regular tracking before you are able to out-drive it.You can grow into it without being in over your head or budget. It will also be durable and easy to setup so you can focus efforts more on the driving. There is far more time to be gained on track from honing your ability than constantly fiddling with dampers that -quite frankly- you don't even know what to do with yet
V-CSL, BBS CH, ÷hlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is offline   Reply With Quote
Old Thu, Jan-10-2019, 12:40:58 AM   #26
M3AZ
///M3AZ
Reputation: 0 M3AZ has disabled reputation
If you're a beginner you're not compromising anything. There are no trophies or money handed out at DEs, just a lot of Miatas that cost less than a set of MCS shocks passing you on the outside.
Jump to top M3AZ is online now   Reply With Quote
Old Thu, Jan-10-2019, 06:30:48 AM   #27
grke36m3
Reputation: 0 grke36m3 is on a distinguished road
I got in on the jrz group buy and went with the jrz rs1 and absolutely love them. I havenít got an alignment yet or even messed with the dampening and they are a worlds better then my old kwv2.
Jump to top grke36m3 is offline   Reply With Quote
Old Thu, Jan-10-2019, 08:00:03 AM   #28
Jaredomin
Jaredomin's Avatar
Id imagine so, im wondering if the pss10 @ around $1800 and a mcs or jrz single @ around $2600.
Which of the two would you prefer?
Is the mcs providing $800 more value. Or are they similar in their offerings/performance?
Old Thu, Jan-10-2019, 11:43:44 AM   #29
HassanEido
HassanEido's Avatar
Lebanon
Pss10s are the shit, period
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Thu, Jan-10-2019, 03:31:32 PM   #30
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
I'm a sucker for monotubes so of those 3, it'd come down to MCS and Bilstein.
Between those 2, I think it comes down to a cost (significant difference between Bilstein and MCS) and details, such as how they are adjusted (on front struts, Bilstein adjuster is on bottom so you'll need to kneel on the ground vs. MCS is on top), inverted strut (Bilstein) vs. regular (MCS), rebuild support, etc.
But I am a JRZ fanboi...so yeah. I don't know lol.
Jump to top Zzyzx85 is online now   Reply With Quote
Discussing What dampers should i buy in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
