Old Wed, Jan-09-2019, 05:11:09 AM   #11
nervous24
Reputation: 0 nervous24 is on a distinguished road
Default Re: What dampers should i buy
I'd advocate for driving your car on a largely stock setup. Get out on track and learn to be safe before you worry about anything else. Your car has more to offer than you can extract anyway. Don't raise its level until you raise yours. You'll appreciate the changes more and get more out of them. Save the money for tires, brake pads and track time.
2003.5 Carbon Black ///M3 @_weaponM
SMG>CAE (1st no drop swap) | MCS | SuperSprint | Rogue | Turner | Bimmerworld | Vorshlag | Hyperco | AKG | PFC | Status Gruppe | Apex | Beisan
Jump to top nervous24 is offline   Reply With Quote
Old Wed, Jan-09-2019, 05:36:15 AM   #12
Kwakjoe
Kwakjoe's Avatar
Originally Posted by Jaredomin View Post
Low interval rebuilds arent enough to deter me.
Any idea how much 2way remote jrz would run me with this group buy?
Unsure. I’d ballpark around 3400-3800 with all hardware etc.
I will echo the same sentiment as everyone else though. The best way to advance as a driver is to do as much as you can with as little as possible.
Old Wed, Jan-09-2019, 05:48:00 AM   #13
lmtfi
lmtfi's Avatar
Originally Posted by herrubermensch View Post
I would go with 2- or 3-way MCS remotes and know you have what many regard as the best damper setup available.
--Peter
If he has a dedicated team suspension technician - maybe. Most Novices lack them though.
Old Wed, Jan-09-2019, 07:44:06 PM   #14
Jaredomin
Jaredomin's Avatar
Reputation: 0 Jaredomin is on a distinguished road
Any other suggestions for a good entry level track oriented set of dampers?
Tck sa i think is a good start butI feel i can get alot more performance if i go into the 3k range? Also concerend if the tck would go as low as id like.
Might just wait and get a used set of something off someone.
If anyone got any nice dampers for sale lmk!
Jump to top Jaredomin is offline   Reply With Quote
Old Wed, Jan-09-2019, 08:00:17 PM   #15
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
You forgot the pro coach and the pit crew. If OP was serious, any shock that isn't blown and a camber plate to save tires is more than enough. But what do I know, just get either a 4-way remote Moton or the PSi Ohlins to pass those pesky Miatas.
Old Wed, Jan-09-2019, 08:02:01 PM   #16
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
I kinda like the MCS 1WNR. According to Vorschlag, they can be upgraded to external reservoir later on if the need arises.
Jump to top Zzyzx85 is offline   Reply With Quote
Old Wed, Jan-09-2019, 08:08:06 PM   #17
Mike RT4
Reputation: 0 Mike RT4 is on a distinguished road
United Kingdom
Read through the Flat Ride thread and then hit ShaikhA up for some custom valved H & R fixed rate dampers.....
CSL No 44 - AP 5575 6-pots front, PF 356 x 32 discs, RS 29 pads / AP 5144 4-pots rear, RS 29 pads - Castrol SRF / Supersprint full system from headers back, inc race cats with "Race" backbox / H&R coilovers / Turner Motorsport RTAB limiter kit
Jump to top Mike RT4 is offline   Reply With Quote
Old Wed, Jan-09-2019, 08:27:56 PM   #18
Jaredomin
Jaredomin's Avatar
I heard the upgrade to cans isnt worth it price wise going from 1wnr.
Ive just about ruled out reservoirs. Too much $ for something i dont need atm.
If im going 2 way remote i might aswell just go 3 way and get all rebound/commpression adjustment my little heart desires.
But im not doing that.
Old Wed, Jan-09-2019, 08:30:38 PM   #19
twentyseven
@itsmejonnyv
twentyseven's Avatar
I'm against premium dampers WITHOUT external resevoirs. MCS/JRZ singles will get the job done, but they are handicapped. Why spend 3k and still leave the biggest benefit on the table in the name of saving money? Many people end up adding them down the road which is a nice feature about the MCS platform but then you will be starting over in terms of setup and you'll be way over your initial budget.
TCK are the answer IF street comfort is a priority. Being a low-pressure twin tube, they gain ride quality from what they give up to a high pressure monotube on the absolute edge. They are the best all-around setup but from your description I don't think it's the best option for your application. Anything higher than a 600lb spring and they aren't in their sweet spot anymore. KW v3 and clubsport are pretty good but they are simply out of their league vs. other offerings in this price bracket.
I have the Ohlins, but again they are not the best choice for you since you want to convert them for track spec.
Against what most people would think, you should consider getting PSS10's. The B16 damper punches well above it's weight and the kit is roughly 1000 less than Ohlins which leaves you plenty of money to get linear springs, camber plates, rsm, SWAYS AND CORNER BALANCING/ALIGNMENT while still staying within your 3k budget. Their digressive valving will behave very similar to the more expensive dampers and the other components will help you build a much better baseline setup than just having a flashy set of dampers. Plus you get dampers that can handle a big spring rate with a lifetime warranty that are simple to dial in [unlike a 3-way]
V-CSL, BBS CH, Öhlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is offline   Reply With Quote
Old Wed, Jan-09-2019, 09:26:34 PM   #20
Jaredomin
Jaredomin's Avatar
@27 interesting suggestion w the pss10. I think you see what predicement im in here.
Everything feels like a compromise or not what im looking for or too much $ for what im getting. I agree with the first comment regarding higher end dampers w/o cans. Based on some other threads regarding jrz/mcs the one thing ive noticed is everyone ends up wanting cans later on.
Discussing What dampers should i buy in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
