Old Wed, Jan-09-2019, 02:55:50 AM   #1
Jaredomin
Jaredomin's Avatar
Reputation: 0 Jaredomin is on a distinguished road
Default What dampers should i buy
I’m seeing alot of options in the 3k range
Car isnt my daily. Will be doing track days.
Track performance>comfortability
Mcs singles- 2650, needs plates/springs/rsm
Ohlins rt- 2600ish, needs plates/springs/rsm
Tck d/a- 3200ish
Kw clubsports 3200ish
Jrz singles
Mcs 2wnr-3350, needs plates/springs/rsm
I realize i am a beginner. I realize seat time>hardware.
I realize suspension is a game of optimization under whatever specific scenario.
That being said, my blown bc coils arent going to cut it.
I dont feel i need to spend much more then 3k range.
Open to doing a trco. Would it be worth to just go for some mcs 2way remotes and never think ab dampers again? Are the singles worth it or would you just go 2way and be done with it?
Help!!
Thanks
Jump to top Jaredomin is online now   Reply With Quote
Old Wed, Jan-09-2019, 03:58:44 AM   #2
M3AZ
///M3AZ
Reputation: 0 M3AZ has disabled reputation
Default Re: What dampers should i buy
Not in your list, but I’ve been thrilled with my ISC N1s. $985 and they include camber plates, rear adjustable perch, and sway bar end links. Their customer support is great. I’ve emailed several times and usually hear back by the next day. The downside of the N1s is no adjustable caster, and no one makes a camber plate to fit them.
I’m not at the point yet where a $4k setup or caster adjustability makes a difference, but I figure by the time I am, I can unload them for $500 and move into the MCS two ways.
Jump to top M3AZ is online now   Reply With Quote
Old Wed, Jan-09-2019, 04:21:46 AM   #3
SeanE46
SeanE46's Avatar
Reputation: 0 SeanE46 is on a distinguished road
Armenia
Originally Posted by M3AZ View Post
Not in your list, but Iíve been thrilled with my ISC N1s. $985 and they include camber plates, rear adjustable perch, and sway bar end links. Their customer support is great. Iíve emailed several times and usually hear back by the next day. The downside of the N1s is no adjustable caster, and no one makes a camber plate to fit them.
Iím not at the point yet where a $4k setup or caster adjustability makes a difference, but I figure by the time I am, I can unload them for $500 and move into the MCS two ways.
How are they for weekend driving? Maybe some track time
2001 M3 6MT TiAg Coupe SOLD
2002 M3 6MT TiAg Coupe SOLD
2004 M3 SMG Silver Grey CURRENT
Jump to top SeanE46 is offline   Reply With Quote
Old Wed, Jan-09-2019, 04:29:31 AM   #4
Kwakjoe
Kwakjoe's Avatar
I recommend either jumping on the group buy for JRZ or go with TCK DA's. Ohlins, KW's are out the picture if your main focus is performance and that's not exactly what they excel at. Cream of the crop is obviously MCS and JRZ, but they can get pricey. Another thing you have to worry about is rebuilds. MCS and JRZ both require much more frequent rebuilds compared to TCK. I believe Obiobian has ran TCK DA's for 50k+ miles with no rebuilds. I'm also currently running them with similar preference of performance > comfort. I drive them on the crappy roads of San Francisco couple times a week. Albeit it is rough, but manageable. The performance is excellent on track and that's a sacrifice I'm willing to make.
Old Wed, Jan-09-2019, 04:43:32 AM   #5
herrubermensch
herrubermensch's Avatar
Reputation: 0 herrubermensch is on a distinguished road
I would go with 2- or 3-way MCS remotes and know you have what many regard as the best damper setup available.
--Peter
Jump to top herrubermensch is offline   Reply With Quote
Old Wed, Jan-09-2019, 04:46:46 AM   #6
M3AZ
///M3AZ
I went with the N1 Track (rates are 560/672). They’re tolerable for a weekend toy or for driving to and from the track when set to full soft, but I wouldn’t want these on a daily driver.
They also make a softer Street version (448/560). Another option is to swap the springs (they accept any 2.5” spring).
https://www.bimmerworld.com/Suspensi...s-Incl-M3.html
Old Wed, Jan-09-2019, 05:12:26 AM   #7
mrgizmo04
mrgizmo04's Avatar
Why would a beginner get 10-way adjustables, based on some of the suggestions? Doesn't sound like you've done much track time upto now? Learn to control or outdrive tck sa then upgrade if you feel you need to.
My $0.02
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Jan-09-2019, 05:15:55 AM   #8
Jaredomin
Jaredomin's Avatar
--Peter
Yea iíll see.
Is the extra 2k necessarily worth it is the question (for me atleast)
Iím not sure i need podium quality at this stage in the game.
It would be nice though.
Old Wed, Jan-09-2019, 05:20:08 AM   #9
Jaredomin
Jaredomin's Avatar
My $0.02
Yea sort of my thoughts. The adjustability would be nice though
That being said..how long will it be “the best damper available”
Old Wed, Jan-09-2019, 05:24:27 AM   #10
Jaredomin
Jaredomin's Avatar
Low interval rebuilds arent enough to deter me.
Any idea how much 2way remote jrz would run me with this group buy?
Discussing What dampers should i buy in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
