Old Fri, Jan-11-2019, 04:27:35 AM   #21
Drewster
Drewster's Avatar
Default Re: Best Oil Cooler (CSF, C&R, OE??)
Originally Posted by BTB View Post
It's seeming like my options are to get hooked up with a CSF for $475 OR do a new OE cooler for $415 which includes the FCP lifetime warranty.. stock with warranty is sounding very enticing. I feel like throwing extra weight low in front of the car is not something I want right now
Yeah, especially if you aren't running into existing problems, OE is always a fine choice
Old Fri, Jan-11-2019, 04:33:25 AM   #22
Kwakjoe
Kwakjoe's Avatar
+1. Brand new OE is the way to go
Old Fri, Jan-11-2019, 04:56:37 AM   #23
I wouldn't bother with fcpeuro for this one - are you really gonna put another 150k quickly and need another one? You can get an OE cooler for $341 online via bmwdirectparts, probably other dealer sites as well like tischer.
https://www.bmwdirectparts.com/oem-p...er-17212228942
_
Old Fri, Jan-11-2019, 05:00:52 AM   #24
I'm going back to OE. Before I do so, I plan to send it here to be cleaned:
http://www.oilcoolers.com/
They have a very positive reputation in the air cooled community, and are pretty cheap:
Thanks for sharing Ian, but is that worth it? Why not spend another $126 and get brand new? Not that $126 is nothing, bit brand new is better than cleaned.
_
Old Fri, Jan-11-2019, 05:14:51 AM   #25
BTB
BTB's Avatar
Huh that is pretty cheap. Was thinking warranty might be worth it on a car that could see snow/ice/gravel though. Definitely thinking OE
My Journal
Old Fri, Jan-11-2019, 05:21:29 AM   #26
Definitely a good reason for fcpeuro there, luckily I don't have to contend with harsh conditions.
_
Old Fri, Jan-11-2019, 06:02:52 AM   #27
mrgizmo04
mrgizmo04's Avatar
Bunch of track guys run oe with no issues, even on hot tracks (hot climates). I was debating getting a CSF, then got convinced to get new OE. I removed the mech fan/shroud, didnt replace it with any additional electric puller and been running track/autox/daily with no issues.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Discussing Best Oil Cooler (CSF, C&R, OE??) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
