Old Mon, Jan-07-2019, 10:29:47 PM   #31
twentyseven
@itsmejonnyv
twentyseven's Avatar
Default Re: Suspension - OEM Sachs vs Bilstein B12 Pro Kit
The pss9/10 even uses the same rear shocks afaik.
No, PSSx kits use the B16 damper.
V-CSL, BBS CH, ÷hlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is offline   Reply With Quote
Old Mon, Jan-07-2019, 11:06:09 PM   #32
scootter82
Reputation: 0 scootter82 is on a distinguished road
Curious about what? Bilstein only makes one set of dampers for this car (not including the pss9/10 or clubsport coilover struts).
You can buy them individually, or in a set of 4, or in a set with eibach prokit lowering springs. The pss9/10 even uses the same rear shocks afaik.
Curious because all the information I can find on the manufacturers and sellers site say it is the B8 damper, even for the E46 M3. No where that I can find other than here says it is B6. I'm not saying anyone is lying, but y'all haven't provided proof to me, and am I supposed to just trust strangers on the internet? If they are not what they said they are, I can always send them back for a refund.
It's confusing when all the info I find says one thing, and forum posters all say another.
Jump to top scootter82 is offline   Reply With Quote
Old Mon, Jan-07-2019, 11:15:56 PM   #33
R60BBA
Reputation: 0 R60BBA is on a distinguished road
United Kingdom
Suit yourself mate.
You will find out when your delivery is delivered!
Anyways - back to the fulcrum of this thread.
I welcome more forum members to share their experiences with both B12 and brand new OEM Sachs suspension.
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
https://youtu.be/y0ymv8jOC0Y
Jump to top R60BBA is offline   Reply With Quote
Old Mon, Jan-07-2019, 11:36:15 PM   #34
EricSMG
40 something
Yep, I get all of that.
Where are you seeing "B8" for this kit? (I haven't looked)
2004 E46 M3 6MT SG/Black
Old Tue, Jan-08-2019, 12:06:32 AM   #35
That's right, they're adjustable and have blue boots. Brain fart.
_
Old Tue, Jan-08-2019, 12:14:59 AM   #36
Look at the part numbers on the shocks in the picture. You can see 35-142102, 35-142119 and 24-113998 -- they all correspond to B6 part numbers.
Old Tue, Jan-08-2019, 12:18:13 AM   #37
icecream
Registered Apples
icecream's Avatar
Well, you have a point. Theyre wensite says b8.
This is directly from them under 2002 BMW M3.
"The BILSTEIN B12 Pro-Kit allows vehicles to be lowered up to 40mm. The kit has the perfect combination of sporty dynamics, aesthetics, and load bearing capacity. This BILSTEIN B12 kits consist of BILSTEIN B8 high-performance shock absorbers that are perfectly matched with EIBACH springs for an optimal ride."
I bet its just an oversite sonce you cannot buy b8 shocks for this platform but you can for pretty mich every other car out there.
Edit: actually it has that description on the front page woth no car selected. So yeah, probably an oversight on their part.
Old Tue, Jan-08-2019, 01:23:52 AM   #38
twentyseven
@itsmejonnyv
B8 are just shortened B6's, which have never been offered for e46 - likely since there are PSS9/10 applications available.
Also shortened, zinc coated, and digressive valving
Old Tue, Jan-08-2019, 01:38:02 AM   #39
R60BBA
United Kingdom
Guys this thread is about peopleís experiences comparing both the B12 Kit and new OEM suspension.
Itís not about an already established fact of what the B12 Kit consists of.
I would be grateful if the thread could remain focused and whether the moderators could clean it up.
Thanks.
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
Old Tue, Jan-08-2019, 02:09:30 AM   #40
Welcome to m3forum, enjoy your stay.
I would be grateful if the moderators could clean it up.
lol how precious.
_
Discussing Suspension - OEM Sachs vs Bilstein B12 Pro Kit in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
