Old Mon, Jan-07-2019, 05:02:52 AM   #11
icecream
Registered Apples
icecream's Avatar
Default Re: Suspension - OEM Sachs vs Bilstein B12 Pro Kit
Originally Posted by scootter82 View Post
Be prepared to wait. I ordered mine a few months ago and they aren't expected to be in stock, anywhere, for another few months. I just installed a set of the B6 all around until my B12 order comes in. My car had been using KW V1's and it was just too harsh.
B12 is b6 with eibachs. You saying eibach Springs are back ordered?
Old Mon, Jan-07-2019, 07:09:15 AM   #12
R60BBA
Reputation: 0 R60BBA is on a distinguished road
United Kingdom
The B12 kit will blow the Sachs/stock springs out of the water it terms of handling/roll/response/tightness. The B12 is very......taught. Totally different than stock. It can be a little firm at times, though. It will eventually settle at around a half inch drop from stock all around which looks killer.
All that said, fresh Sachs on an otherwise fresh factory setup is quite plush and still handles very good. So it depends on if you want max comfort or more of an edge.
In between these two options sits the Koni/Dinan setup. Less aggressive than B12 but more sporty than stock....same drop as B12....ish.
Cheers Eric
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
https://youtu.be/y0ymv8jOC0Y
Jump to top R60BBA is offline   Reply With Quote
Old Mon, Jan-07-2019, 03:18:12 PM   #13
R60BBA
United Kingdom
+1.
Also if you already have the B6 damper, why not just order the springs from Eibach?
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
Old Mon, Jan-07-2019, 03:21:15 PM   #14
scootter82
Reputation: 0 scootter82 is on a distinguished road
I have the B6 HD's. I thought the B12's with Eibachs were the lowered springs with different sturts/shocks to accomodate the slightly lowered stance? Are the struts and shocks really the same between the two??
Jump to top scootter82 is offline   Reply With Quote
Old Mon, Jan-07-2019, 03:32:42 PM   #15
R60BBA
United Kingdom
The B12 Kit consists of Bilstein’s B6 damper and Eibach Pro Kit lowering springs.
However I believe it was revised a few years back as it was initially sold with H&R springs.
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
Old Mon, Jan-07-2019, 03:48:10 PM   #16
scootter82
From the Bilstien website:
"This BILSTEIN B12 kits consist of BILSTEIN B8 high-performance shock absorbers that are perfectly matched with EIBACH springs for an optimal ride."
https://www.bilstein.com/us/en/produ...n-b12-pro-kit/
https://www.bilstein.com/uploads/tx_...6_b8_en_35.pdf
BILSTEIN B6
Performance you can feel.
If you expect more damping power from your shock ab-
sorber – even under loads – but don’t want to opt for an
all-out sports model, the BILSTEIN B6 is the ideal solution.
BILSTEIN B8
Shortened high-performance shock absorbers
for virtually every lowering spring set and series
production sport vehicles
Old Mon, Jan-07-2019, 03:58:23 PM   #17
scootter82
Should be B8's with Eibachs. I tried Bimmerworld and Amazon, didn't try anywhere else. BW told me it could be 6 months before they are in. My Amazon order says not to expect them till mid Feb, and I placed the order back in Nov.
Old Mon, Jan-07-2019, 04:01:34 PM   #18
R60BBA
United Kingdom
BILSTEIN B6
BILSTEIN B8
Bilstein did not make B8 dampers for the E46 M3.
As previously said B12 Kit for E46 M3 = B6 dampers + Eibach springs.
https://www.bilsteinuk.com/pages/pro...9808;car=bmwm3
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
Old Mon, Jan-07-2019, 04:08:14 PM   #19
R60BBA
United Kingdom
More experiences / feedback on the above mentioned suspension set-ups are welcome.
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
Old Mon, Jan-07-2019, 04:11:06 PM   #20
HassanEido
HassanEido's Avatar
Lebanon
The b12 are b6s. The b8s were for the none M as stated above.
I haven't driven on those with eibachs. But on vogtlands with the bump stops shortened, they are out of this world better. Like you wouldn't believe the difference it makes. Super super planted. U can keep ur foot in it in corners. Like 10 times more grip I kid u not.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Discussing Suspension - OEM Sachs vs Bilstein B12 Pro Kit in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
