Old Sun, Jan-06-2019, 08:02:33 PM   #1
R60BBA
Reputation: 0 R60BBA is on a distinguished road
United Kingdom
Default Suspension - OEM Sachs vs Bilstein B12 Pro Kit
M3Forum members,
I'm looking at refreshing my 80,000 mile OEM suspension this year but am stuck between replacing with new OEM Sachs or switching to the Bilstein B12 Pro Kit (Bilstein B6 dampers & Eibach Pro Kit Lowering Springs).
I have heard that the B12 Kit while firmer provides better handling than the OEM Sachs set up, however from a stance perspective the front sits higher than stock...
I welcome those who have tried both set-ups to share their experiences in this thread.
N.B. I intend to use the car for fast road use and up to 4 track days per year.
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
https://youtu.be/y0ymv8jOC0Y
Jump to top R60BBA is online now   Reply With Quote
Old Sun, Jan-06-2019, 08:07:00 PM   #2
Default Re: Suspension - OEM Sachs vs Bilstein B12 Pro Kit
Billys will blow stock away. Even konis with eibachs. I wouldn't worry about ride height too much - it'll never really be what you want with a shock/spring combo. Might get close with Vogtland's nice and even 1" all around drop. There was a set for sale on here for a good price recently.
My plan, if I don't come across a better pair of dampers for cheap, is to get billy struts and have the gas pressure lessened a bit and inner bump stop shortened.
_
Old Sun, Jan-06-2019, 08:34:07 PM   #3
R60BBA
United Kingdom
Thanks for your feedback, however I would like for this thread to solely concentrate on people's experience of using either a new set of OEM Sachs or the Bilstein B12 kit.
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
Old Sun, Jan-06-2019, 08:47:42 PM   #4
Well one is better than the other what do you want?
You could also search. Both these options have been around for years.
_
Old Sun, Jan-06-2019, 08:54:50 PM   #5
R60BBA
United Kingdom
Iíve done quite a lot of research, and from reading various threads on numerous forums it seems like there is a mixed opinion on the B12 kit.
Also there is no thread out there which concentrates solely on these 2 suspension set ups. Thus to contain all this information in one thread would be quite useful I think.
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
Old Sun, Jan-06-2019, 09:13:05 PM   #6
twentyseven
@itsmejonnyv
twentyseven's Avatar
If you don't specifically want a sharper, edgier ride then don't get the Bilsteins. They will behave better than your 80k Sachs but won't be as comfortable on the road. Koni's are generally accepted as a better all-around damper when using stock springs.
Search for EricSMG's posts, or wait for him to chime in here...
V-CSL, BBS CH, ÷hlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is online now   Reply With Quote
Old Sun, Jan-06-2019, 09:25:30 PM   #7
R60BBA
United Kingdom
Thanks for the feedback, much appreciated.
I welcome otherís opinions.
E46 M3
S54B32
Carbon Schwarz
IG: bavarianjunkie
Old Mon, Jan-07-2019, 01:32:06 AM   #8
icecream
Registered Apples
icecream's Avatar
Nuts how polarized people are on this. I have read consistent, similar and good reviews on the billies which leads me to think they are a superior shock. The biggest controversy is the final ride hwifht on them.
They are 623 right now on ecs, really tempted to pick them up to replace my B4's.
Old Mon, Jan-07-2019, 02:46:47 AM   #9
EricSMG
40 something
The B12 kit will blow the Sachs/stock springs out of the water it terms of handling/roll/response/tightness. The B12 is very......taught. Totally different than stock. It can be a little firm at times, though. It will eventually settle at around a half inch drop from stock all around which looks killer.
All that said, fresh Sachs on an otherwise fresh factory setup is quite plush and still handles very good. So it depends on if you want max comfort or more of an edge.
In between these two options sits the Koni/Dinan setup. Less aggressive than B12 but more sporty than stock....same drop as B12....ish.
2004 E46 M3 6MT SG/Black
Old Mon, Jan-07-2019, 03:46:25 AM   #10
scootter82
Reputation: 0 scootter82 is on a distinguished road
Be prepared to wait. I ordered mine a few months ago and they aren't expected to be in stock, anywhere, for another few months. I just installed a set of the B6 all around until my B12 order comes in. My car had been using KW V1's and it was just too harsh.
Jump to top scootter82 is offline   Reply With Quote
Discussing Suspension - OEM Sachs vs Bilstein B12 Pro Kit in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
