Old Sun, Jan-06-2019, 06:34:34 PM   #1
Mindart
Reputation: 0 Mindart is on a distinguished road
Default door stop pin issue
hey guys... replaced my door stops today ( with genuine parts) i decided top replace the pins as well
drivers side , had no issues getting it all back together... but the passenger side was different story
while driving the the pin in a noticed the tap the pin goes through, that surrounds the door stop bracket started to separate. needless to say it was a pain in the ass to back out but i did.
any idea of what is going on here.. do i have a bigger problem on my hands? I have decided to step away from this today to try to figure out if I did something wrong or if there is a larger underlying issue with the sheet metal here
any thoughts or suggestions greatly appreciated. I have attached pics of the drivers side which is fine... and then a couple of the passenger side which is not
thanks!
Jump to top Mindart is offline   Reply With Quote
Old Tue, Jan-08-2019, 11:30:20 PM   #2
M3AN
321 fun...
M3AN's Avatar
New Zealand
Default Re: door stop pin issue
If I've understood you corrcetly...
- Have you tried and pre-compress the bottom of the pin so you don't have to use so much force?
- What about holding the bracket "closed" with vice grips or similar whilst you drive the pin in?
E36 M3 Coupe | S50B32 | 6MT | Estoril Blue | Z3 Rack | Simota Intake | Remus Exhaust | Bilstein B6 | Eibach Pro+ | 18" BBS RC | Goodyear F1 | 3.62 Gear Set (Yet To Be Installed)
Old Tue, Jan-08-2019, 11:43:55 PM   #3
Mindart
Yeah, i'll do that... I don't know what the issue was with this new pin be clearly it wasn't going in straight... not sure how that is possible but clearly I had an issue.
I'll take some large pliers and squeeze back together those tabs ( I hope I didn't cause structural damage to it) and will probably end up doing some vice grips or be certain the pin is aligned correctly before I start hammering again. Just don't get why the drivers side was so easy to do yet i am having issues on the passenger side
Kind of a silly design.... I like e46 much better with the E-Torx rather than fiddling with this stupid pin
thanks for chiming in....
Discussing door stop pin issue in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
