Old Thu, Jan-10-2019, 10:28:29 PM   #21
jayyym3
Reputation: 0 jayyym3 is on a distinguished road
Default Re: Cranks but does not start
No longer a fuel related issue. Fuel is going to the engine but there is no spark. I replaced the spark plugs and CPS. I ordered one from Oreilys which ended up being a BMW OEM part for half of the price. I'm now trying out a DME relay today after work. Not sure of anything else that would cause a spark issue.
Jump to top jayyym3 is offline   Reply With Quote
Old Thu, Jan-10-2019, 11:54:15 PM   #22
ThunderMoose
How are you checking for spark?
#67 2017 NASA TX TT3 Champion
Old Fri, Jan-11-2019, 06:20:45 AM   #23
jayyym3
I tested it again and got spark this time. I wasnt grounding the spark plug correctly. So Im getting fuel and spark at this point so not sure what to do next.
Old Fri, Jan-11-2019, 06:57:05 AM   #24
mrgizmo04
mrgizmo04's Avatar
Crank/cam/maf sensors?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Jan-11-2019, 01:00:15 PM   #25
ThunderMoose
Id do a leak down test and make sure theres not an issue with compression.
Then I would look at vanos operation. Easiest thing to do is remove and clean the vanos solenoid body.
You can also pop the end cap of the intake cam. That piston should be in about 5-10 mm with the car off. In my experience if vanos is not operating properly, it will prevent engine from catching.
Old Fri, Jan-11-2019, 05:14:46 PM   #26
jayyym3
Crank was already replaced. I saw most cam issues cause a engine light to go on. I had a bad maf once before. It would crank and stark for a second or two before stalling. Now it just cranks and doesnt start with or without the MAF connected.
Old Fri, Jan-11-2019, 05:16:54 PM   #27
jayyym3
The car was running fine. Not sluggish or problematic prior it to dying while running. Would this be an indicator that the vanos is fine. I was thinking that the bump on the road loosened something.
Old Fri, Jan-11-2019, 05:33:31 PM   #28
mrgizmo04
mrgizmo04's Avatar
Vanos, even if broken, will get stuck in one position rather than dynamically update timing, but the car should still run, albeit kind of rough in a certain rpm range.
'05 M3 6MT coupe
Old Fri, Jan-11-2019, 07:01:35 PM   #29
ThunderMoose
Well it could be a head gasket, but Id try the other stuff first.
Old Sat, Jan-12-2019, 08:27:18 AM   #30
berto
Reputation: 0 berto is on a distinguished road
You should hear the SMG pump prime when you unlock/open your car. I'm still able to switch between neutral and 1st gear. If yours isnt doing this then look into the salmon relay.
yeah im good on that its engaging fine fine but nothing on the display. i used my back up salmon relay that was not the issue i can hear it changing gears fine from underneath all the pumps prime well all the fuses are in check ... driving me crazy!!! could it be some sort of safe mode i dont know about?
Jump to top berto is offline   Reply With Quote
Discussing Cranks but does not start in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
