Old Sat, Jan-05-2019, 02:14:07 AM   #11
wichonewichone
Reputation: 0 wichonewichone is on a distinguished road
Default Re: Cranks but does not start
Crankshaft sensor maybe
Would imagine that would throw a code
Jump to top wichonewichone is offline   Reply With Quote
Old Sat, Jan-05-2019, 03:07:03 AM   #12
bmwe46nyc
Reputation: 0 bmwe46nyc is on a distinguished road
I was not not throwing any codes hence the headaches....but step by step I figured that it wasn’t fuel pump, then changing sensor here and there, fuel filter, fuel filter bar, injectors, spark plugs etc then I changed o2 sensors and temp sensor and gucci
Jump to top bmwe46nyc is offline   Reply With Quote
Old Sat, Jan-05-2019, 07:33:19 PM   #13
What?
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · WPC'd OE bearings · oil catch can · fan/SAP/washer delete · CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/600) + tall RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Sat, Jan-05-2019, 07:56:40 PM   #14
mrgizmo04
mrgizmo04's Avatar
Lol, so it was a bad gucci?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Jan-05-2019, 08:22:00 PM   #15
11b4
11b4's Avatar
I hate when the Gucci goes bad.
Old Wed, Jan-09-2019, 06:54:15 AM   #16
berto
Reputation: 0 berto is on a distinguished road
hey whats Gucci ? and did the car start?
i am having a similar issue now also i am not getting any numbers on the gear display on the dash board so i am thinking its an SMG issue but i ran most diagnostics and checked most fuses i and cant seem to get it to start. its weird she even cranks without pressing on the break !!
Jump to top berto is offline   Reply With Quote
Old Wed, Jan-09-2019, 11:46:54 AM   #17
bmwe46nyc
Lol....Gucci is slang for like perfect.....meaning that when I changed my air temp sensor under manifold and all of o2 sensors that solved my problem. But for me I think it was the o2 sensors.....
Old Wed, Jan-09-2019, 12:38:32 PM   #18
ThunderMoose
O2 sensors are open loop for first little bit of operation. I wouldn’t think that this would prevent car from starting up. But not going to argue results.
#67 2017 NASA TX TT3 Champion
Old Wed, Jan-09-2019, 12:54:43 PM   #19
berto
Ohh ok... lol ��
Old Wed, Jan-09-2019, 05:41:44 PM   #20
jayyym3
Reputation: 0 jayyym3 is on a distinguished road
You should hear the SMG pump prime when you unlock/open your car. I'm still able to switch between neutral and 1st gear. If yours isnt doing this then look into the salmon relay.
Jump to top jayyym3 is offline   Reply With Quote
Discussing Cranks but does not start in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
