Old Fri, Jan-04-2019, 10:29:16 PM   #1
jayyym3
Reputation: 0 jayyym3 is on a distinguished road
Default Cranks but does not start
Couple days ago I started up the car and as Im driving up the parking lot ramp the car shuts off half way up. I tried starting it up again but only cranks and does not start now. I immediately connected INPA but I did not get any codes. I do hear the fuel pump but sounds a bit loud. I swapped the green fuel pump relay. I tested the voltage to the fuel pump and is reading 11.5v but I'm not sure if thats due to the battery draining from the attempted start ups. The car has 100K miles on it and do not know the history. Any suggestions would be helpful.
UPDATE: replaced fuel pump, spark plugs and CPS. There’s spark and fuel is making it to the cylinders. Battery is less than a year old.
Jump to top jayyym3 is offline   Reply With Quote
Old Fri, Jan-04-2019, 10:48:57 PM   #2
11b4
11b4's Avatar
Default Re: Cranks but does not start
Someone can chime in, I'm not 100% sure, but I believe there's a fuse that deals with the fuel pump located under the hood in the black ecu box. Not 100% positive though.
Old Fri, Jan-04-2019, 10:49:58 PM   #3
bmwe46nyc
Reputation: 0 bmwe46nyc is on a distinguished road
In my case after a couple of months changing parts, I changed the sensor under the manifold and 02 sensors and havenít had a problem since. Iím supercharged so that complicated things at first thinking it was related to that....and it happened after car over heated cause aux fan went bad....for future reference u can hold car in cranking position for like 30 to 40 sec and car should start....but I donít know if thatís good long term.....
Jump to top bmwe46nyc is offline   Reply With Quote
Old Sat, Jan-05-2019, 12:03:57 AM   #4
Pnick
Pnick's Avatar
FYI...not a good thing to hold it 30 - 40 seconds. You'll end up burning up your starter. Starter draws high cranking amps and that results in a lot of heat. Recommended 8 - 10 second cycle.
Fuel pump relay is black and the green one is for the defogger if I'm not mistaken.
Fuse F3 located in the engine electronics box is a 20A fuse...though it seems like your fuel pump is running.
Jump to top Pnick is online now   Reply With Quote
Old Sat, Jan-05-2019, 12:09:54 AM   #5
bmwe46nyc
Yes, you are right but in emergencies situation u have to do what u have to do now I did this for a couple of months and I have not noticed any drawbacks......but like I said common sense tells u that is not normal to do it...
Old Sat, Jan-05-2019, 12:53:18 AM   #6
jayyym3
Thanks guys. I swapped out the fuel pump with a new one but no luck. Itís way quieter so it was most likely going to crap out soon anyways. Iíll try to get a black fuse ASAP. Is a 11.5v reading an indicator that the black relay is shot? As far as grounds go. Is there any I should look for that may have gotten lose?
Old Sat, Jan-05-2019, 01:16:04 AM   #7
mrgizmo04
mrgizmo04's Avatar
Check fuse 54 in the glovebox.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Jan-05-2019, 01:53:50 AM   #8
jayyym3
I did. I wish it wouldíve been that lol
Old Sat, Jan-05-2019, 02:12:14 AM   #9
wichonewichone
Reputation: 0 wichonewichone is on a distinguished road
EWS issue? If it cranks but no start. Your missing fuel or spark.
Jump to top wichonewichone is offline   Reply With Quote
Old Sat, Jan-05-2019, 02:13:32 AM   #10
Crankshaft sensor maybe
Discussing Cranks but does not start in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
