Old Fri, Jan-04-2019, 06:56:48 PM   #31
ctdriver86
Reputation: 0 ctdriver86 is on a distinguished road
Default Re: Aluminum steering coupler
I too, have the an aluminum coupler. 1 year, about 25k miles, 7 track days. Steering still feels the same. More responsive, but also more sensitive so definitely need a well calibrated tire balancer, good bushings, and good alignment
Jump to top ctdriver86 is offline   Reply With Quote
Old Fri, Jan-04-2019, 07:10:41 PM   #32
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Stay alive brother, God willing.
Old Fri, Jan-04-2019, 07:47:39 PM   #33
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Awesome, Im sub'd. Hope it fits
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable 500lbs Front 600lbs Rear/TCKline Camber Plates/TMS Adjustable Rear Control Arm/Powerflex Black RTABs/Turner Delrin FCABS/ Brembo GT 6 pot F 4 Pot R/OEM CSL Trunk/ SGT 1 piece lip
Jump to top Sandeep1212 is offline   Reply With Quote
Old Fri, Jan-04-2019, 10:15:31 PM   #34
AussieE46M3
Reputation: 0 AussieE46M3 is on a distinguished road
Hope you guy's don't mind me skipping most the thread but, I just wanted to mention that the current CMP aluminium steering coupler I offer is for RHD vehciles only.
Another forum member shared some measurements in the GB Feeler thread of a LHD unit he had available and the measurements do not match what we have over here.
Just to illustrate, I've linked it below.
http://cmpautoengineering.com/produc...ering-coupler/
As a side note, it appears that the LHD joints only have a single UJ while ours have one top and bottom of the coupler likely making binding much less of an issue.
Sorry if there was any confusion.
Jump to top AussieE46M3 is online now   Reply With Quote
Old Sat, Jan-05-2019, 08:49:23 PM   #35
DoubleSidedTape
Reputation: 0 DoubleSidedTape is on a distinguished road
I'm running the Condor steering coupler. No additional NVH from what I can tell, just more direct steering.
Jump to top DoubleSidedTape is offline   Reply With Quote
Old Sat, Jan-05-2019, 09:00:32 PM   #36
stash1
Hmmm, how exactly does it attach to the steering shaft? Those look like set screws? at 90* apart?
'04 AW/IR...some mods
Old Sat, Jan-05-2019, 09:01:41 PM   #37
Yeah seems like it uses set screws, which I'm not a fan of. I'm hoping the I8 or Z8 piece works (hopefully i8 since that's considerably cheaper)
Old Sat, Jan-05-2019, 09:12:18 PM   #38
stash1
Ya, set screws (when properly installed) are generally reliable, but are used primarily in industrial equipment. If one were to 'spot' the shaft where the set screws contacted...that would add a degree of confidence...but I still don't know how I would feel about what amounts to basically having some fancy set screws attaching my steering wheel to the front tires.
Old Sat, Jan-05-2019, 10:51:07 PM   #39
rbg
Reputation: 0 rbg is on a distinguished road
I would imagine that making a proper u-joint would be much more complicated than replicating the way an OEM one attaches, don't know...
Jump to top rbg is offline   Reply With Quote
Old Sat, Jan-05-2019, 10:56:50 PM   #40
And yet, for pretty much any car, I can't find an aftermarket one that mounts similarly to OE, while pretty much all OE pieces (regardless of make) have a similar clamp mount.
Discussing Aluminum steering coupler in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
