Old Fri, Jan-04-2019, 02:27:52 PM   #21
Default Re: Aluminum steering coupler
Originally Posted by CrookedCommie View Post
Nope. Not doing anything that increases the chance of steering failure. Last thing I want.
Another great AKG product, though
Old Fri, Jan-04-2019, 02:40:03 PM   #22
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Gonna need a citation on that, lol. Been running that one for three years, still have steering.
Old Fri, Jan-04-2019, 02:45:37 PM   #23
As Terra said in the other thread:
Yeah you're right. But also notice the RHD piece has a u joint after the coupler while the LHD piece does not. In the case of the LHD cars, I think a solid disk would put extra stress on the pinion.
Or, looking at what BMW did, which is often a good guide-- in every single car with a steering rack, they have a joint at the top and bottom of the shaft. Sometimes that joint is rubber (e46 m3), sometimes it's metal (Z8, i8, z4M, e9X M3)-- but it always exists. I doubt they're doing it if it's optional.
I wouldn't expect immediate failure, so your 3 years of not many miles/year isn't surprising.
Old Fri, Jan-04-2019, 02:54:25 PM   #24
CrookedCommie
Captain Slow
Bulgaria
So there isn't one instance of failure, just that there's a possibility, got it. I'll report back in another 3 years.
Old Fri, Jan-04-2019, 02:58:22 PM   #25
Assuming you survive failure
Old Fri, Jan-04-2019, 03:09:40 PM   #26
fuztupnz
Reputation: 0 fuztupnz is on a distinguished road
This thread is full of dumb. How do you people survive like this?
Jump to top fuztupnz is offline   Reply With Quote
Old Fri, Jan-04-2019, 03:12:14 PM   #27
rbg
Reputation: 0 rbg is on a distinguished road
If that doesn't fit, will likely try the Z8's (32311096444):
Why did you abandon your first idea about e28/e34/e23/e32 coupler?
Looks like it works for e36: http://www.m3forum.net/m3forum/showp...33&postcount=2
Jump to top rbg is offline   Reply With Quote
Old Fri, Jan-04-2019, 03:24:11 PM   #28
E46 steering shaft has a different fitting (close to the shape of what you see in that Z8 coupler above, though it’s unclear if they’re the same size)
If you go searching older posts there are reported instances of failure on the e36, which have a similar setup to our cars.
Old Fri, Jan-04-2019, 03:29:13 PM   #29
rbg
I did mine a couple of years ago and do not remember exactly, but isn't it how it looks?
I remember number 1, but what is number 3 there at realOEM
Old Fri, Jan-04-2019, 03:55:33 PM   #30
3 and 4 are the rhd pieces
Discussing Aluminum steering coupler in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
