Old Thu, Jan-03-2019, 05:12:44 PM   #1
rbg
Reputation: 0 rbg is on a distinguished road
Default Aluminum steering coupler
As there is a CMP GB going on I am really considering getting their alu steering coupler. I donít care much for NVH, but people say about accident safety and etc. I was really wondering if it that bad? If you look into steering column it should collapse itself and I would not imagine that that piece of rubber compare to the solid part will make any difference.
Jump to top rbg is online now   Reply With Quote
Old Thu, Jan-03-2019, 05:46:32 PM   #2
hbalzanya69
Reputation: 0 hbalzanya69 is on a distinguished road
Default Re: Aluminum steering coupler
It will eventually break your steering column. If you want to delete the rubber steering bushing purchase a Z4M coupler, it's a U joint instead of a rubber coupler.
Z4M Steering Coupler
Jump to top hbalzanya69 is offline   Reply With Quote
Old Thu, Jan-03-2019, 05:58:31 PM   #3
Has anyone tried using the e28/e35 M5 U joint with the M3 telescoping shaft?
If it fits, same result as the Z4M at 1/3 the price, with an easier install to boot.
M3: http://www.realoem.com/bmw/enUS/show...diagId=32_0645
Z4: http://www.realoem.com/bmw/enUS/show...diagId=32_1382
e28: http://www.realoem.com/bmw/enUS/show...diagId=32_0399
Old Thu, Jan-03-2019, 07:20:17 PM   #4
Update: the e28/e34 joint does not fit.
Old Thu, Jan-03-2019, 07:30:08 PM   #5
Does it not fit because a chamfer has not been added for the securing bolt? I recall reading about something like this recently.
Old Thu, Jan-03-2019, 07:37:16 PM   #6
M3AZ
///M3AZ
M3AZ's Avatar
Reputation: 0 M3AZ is on a distinguished road
I bought an aluminum coupler with the intent of testing it someday, but I agree with the other comments that a U-joint is the right way to go if you want to eliminate the rubber guibo. Condor sells one.
Aside from losing brakes, losing steering is about the worst thing that can happen in a car, especially on a racetrack. I'm not convinced that the increased risk is outweighed by what is likely a nominal improvement in steering response.
Old Thu, Jan-03-2019, 07:44:19 PM   #7
aznbo187
XIII
aznbo187's Avatar
Does the Z4M then not come with any type of steering dampening stock?
no.13
Jump to top aznbo187 is online now   Reply With Quote
Old Thu, Jan-03-2019, 07:47:34 PM   #8
I may have been mistaken about the safety aspect (I misunderstood what bmw was emphasizing in various docs), but I do think a u joint would be a better solution than a disc.
However, it’s also important to retain that lower steering shaft - that does indeed play a safety role.
Edit: Looks like the condor piece would work well - seems to retain the stock lower shaft unlike their solutions for other models
Old Thu, Jan-03-2019, 08:48:25 PM   #9
rbg
So z4M U-joint can be used or not? Looking on the realOEM I just can understand what part and how to install on our cars.
Old Thu, Jan-03-2019, 11:38:07 PM   #10
M3AZ
///M3AZ
M3AZ's Avatar
However, itís also important to retain that lower steering shaft - that does indeed play a safety role.
I think it does serve a safety purpose. A crumple zone and airbag wouldn't do much good if the steering column turned into a 4 foot spear that would end up in the back seat in a crash.
Discussing Aluminum steering coupler in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
