Old Thu, Jan-03-2019, 03:59:15 PM   #1
Shaun55F
Hello
Shaun55F's Avatar
Reputation: 0 Shaun55F is on a distinguished road
Default Is this valve cover salvageable?
Hey guys. Been a while. Anyway, I'm doing a bunch of work, and I'm about to replace my Vanos. I pulled off my valve cover, and I discovered this bit that was scraped/sheared away. It's at the rear driver-side corner. What are my options? Obviously, I'd rather not drop more coin on a new valve cover if this could be made to work. However, I don't want to skimp out and have a guaranteed oil leak. Thanks!
https://ibb.co/c20y0D4
https://ibb.co/cQjS1jG
Jump to top Shaun55F is offline   Reply With Quote
Old Thu, Jan-03-2019, 04:32:11 PM   #2
abcurran
abcurran's Avatar
Default Re: Is this valve cover salvageable?
Guaranteed to leak? Only one way to find out.
The only guarantee you have, is an increased likelihood of a leak by reinstalling that cover.
These things aren't cheap - about $380 - so I understand hoping to reuse. But if that's the original cover, I'd venture it's already slightly warped and brittle from so many heat cycles that, even if that one section wasn't broken, chances are it would leak somewhere else.
Old Thu, Jan-03-2019, 05:07:05 PM   #3
That is inside the seal. If it didn’t leak before, just use it or go to the junk yard for a new one.
Old Thu, Jan-03-2019, 06:17:27 PM   #4
Shaun55F
Hello
Shaun55F's Avatar
Thanks for the prompt response, guys. Brett, that's what I was thinking...it's the inside, so hopefully it's not terminal. I'm going to button her up and hope for the best. Thanks again.
Discussing Is this valve cover salvageable? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
