Old Thu, Jan-03-2019, 02:54:34 PM   #1
zippity
Reputation: 0 zippity is on a distinguished road
Default Driver's Door Won't Unlock
I've done some searching, but most people are having different symptoms.
When I lock my doors, the only way I can unlock the driver's side door is by pulling the handle from inside the car. When I hit the unlock button, only the passenger side will unlock. When I try to use the key manually from outside of the car, I'm not able to move the key all the way to unlock the door. Almost like something is jammed or holding it up. But again, when inside, I can just pull the door release and it unlocks with ease. Any suggestions?
Jump to top zippity is offline   Reply With Quote
Old Thu, Jan-03-2019, 03:38:27 PM   #2
Drewster
Drewster's Avatar
Default Re: Driver's Door Won't Unlock
Door lock actuator.
Exact same thing happened on my truck - they still let you get out (in an emergency, etc.) but the key and solenoid won't do anything when it's jammed up.
Old Thu, Jan-03-2019, 08:43:03 PM   #3
atsantone
Reputation: 0 atsantone is on a distinguished road
Door lock actuator.
Jump to top atsantone is online now   Reply With Quote
Old Fri, Jan-11-2019, 04:54:19 PM   #4
zippity
Door lock actuator.
Can anyone confirm that this is the part and correct corresponding part number for drivers side?
https://www.fcpeuro.com/products/bmw...m3-51217011247
Looks like I can find one on summit racing for about $105 or a used one off of eBay for $50-$70.
Old Fri, Jan-11-2019, 08:37:06 PM   #5
rve
In ///M we trust.
rve's Avatar
Reputation: 0 rve is on a distinguished road
Bulgaria
Yep, seems like that's still the effective part. Mine also failed showing exactly the same symptoms nearly 5 years ago.
The throttle remains in "Sport" mode, the DSC is Off and the smile just gets wider... and wider...
Jump to top rve is offline   Reply With Quote
Old Sun, Jan-13-2019, 06:33:36 AM   #6
moezer
moezer's Avatar
Reputation: 0 moezer is on a distinguished road
I got a doorman name brand for mine when it went bad off of amazon works great
Sent from my SM-N950W using Tapatalk
Jump to top moezer is offline   Reply With Quote
Discussing Driver's Door Won't Unlock in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
