Old Sun, Dec-30-2018, 12:25:30 AM   #1
///mtree
Reputation: 0 ///mtree is on a distinguished road
Default Need some help with Brembo rear calipers
Good Afternoon all,
I was hoping I could get some help from you all. A while back I purchased a set of Brembo rear calipers. I was told these were a discontinued piece from Brembo as they are now sold in a complete set with larger rotors. This was supposed to be a rear calipers upgrade that utilizes the stock 328mm rotor.
I didnít get a chance to install them when they arrived but Iíve now started working on the car and got around to doing the brakes. I have run in to an issue. The brackets line up with the mounting points on the ďearsĒ and install fine but when I have the rear rotor in place the caliper brackets are too ďshortĒ as in the caliper itself rests on the edge of the rotor and doesnít go far enough down to line up with the mounting holes.
Has anyone used this set or are familiar with it? Iím wondering if Iím using the wrong rotor or this was meant for another vehicle?
Iím attaching photos of the caliper with the bracket as well as the bracket by itself for reference.
Jump to top ///mtree is offline   Reply With Quote
Old Sun, Dec-30-2018, 06:06:44 AM   #2
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
What are the part numbers on the rear calipers you have? In the DIY link PM TboneM3 "Tyler" and see if he can assist you.
PORSCHE CALIPERS:
996.351.425 (driver side front)
996.351.426 (passenger side front)
996.352.421 (driver side rear)
996.352.422 (passenger side rear)
Porsche 996 BREMBO BBK Photo DIY
http://www.m3forum.net/m3forum/showthread.php?t=600427
Old Mon, Dec-31-2018, 08:21:11 AM   #3
Zabalzae
Zabalzae's Avatar
Reputation: 0 Zabalzae is on a distinguished road
Default Re: Need some help with Brembo rear calipers
I mean if it’s hitting the rotor then maybe wrong caliper, bracket or they mill down the caliper for a different car. Also did you trim the shield?
02 M3 SMG->6MT - Tiag/Cinnamon
RK-Tunes Alpha N | Evolve Airbox | Eventuri Scoop | SGT Headers | SGT-SCZA-FRP | CPI Euro200R | RE El Diablo | APEX | AKG | PowerFlex | Beisan | TMS Reinforcement | BC | VibraTechnics | StopTech ST40 | TMS (3)Pulleys | BMW Performance SS w/ F10 knob | Bavsound |
Jump to top Zabalzae is offline   Reply With Quote
Old Mon, Dec-31-2018, 08:33:31 AM   #4
Perhaps you were lied to about it fittong this car? Sounds like this set is not meant for a 328mm rotor, or there are mismatched brackets? Whatever distance it is from the bottom of your pads to the bottom of the rotor face, is how much thicker you'd need those brackets to be or how much less, than 328mm, the rotors these fit would be. You can buy proper brackets direct from brembo, I believe, if that's the issue. Look for your calipers' part #. Post it here for reference, if you would.
These calipers aren't 996 porsche brembos, so the brackets you might see mentioned often here or see on ebay or ecs, wouldn't be what you'd need, afaik.
_
Old Tue, Jan-01-2019, 05:43:50 AM   #5
tey elvis
Reputation: 0 tey elvis is on a distinguished road
Singapore
Are you sure you have the 328mm stock rotors and not the csl ones?
Sent from my SM-N960F using Tapatalk
Jump to top tey elvis is offline   Reply With Quote
Old Tue, Jan-01-2019, 06:45:16 AM   #6
irrelevant, though, because they're the exact same dims, 328mm x 20mm.
_
Old Tue, Jan-01-2019, 07:12:01 AM   #7
tey elvis
Singapore
My bad
Old Tue, Jan-01-2019, 07:05:57 PM   #8
///mtree
Thanks for the responses. I was looking for a number on the caliper and I found some markings on the inside and bottom which were difficult to make out. It looks like on the inside of the caliper on the non mounting side (where the black Brembo lettering is) it is marked with
1 6972 02
The inside half where the caliper mounting bracket is looks like
1 6971 02
The bottom of the caliper looks to be staged with
S (could be an 8) 340 (maybe 346?)
Iím not sure how part designation is done on these.
Old Tue, Jan-01-2019, 07:14:06 PM   #9
///mtree
I also took a picture of the part number on the mounting bracket.
It says P/N 90.2551-B S/N 0203009
Old Thu, Jan-10-2019, 04:01:37 AM   #10
tey elvis
Singapore
Problem solved?
Discussing Need some help with Brembo rear calipers in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
