Old Thu, Jan-03-2019, 12:07:52 AM   #31
STAATS
STAATS's Avatar
Default Re: 3D printed brake duct project update.
Originally Posted by bigjae1976 View Post
There is a tried and true route for the hose so that there's no interference. You will need to cut the plastic engine cover. You can use these flanges to make the connection easily removable for street driving.
https://www.aircraftspruce.com/catal...uctflanges.php
These are not necessary. If you route the hose right there will be no need to ever remove the hoses.
Cool. Thanks for the link.
Whats the tried and true route? Any link for that? I have no problems cutting/modifying things providing I can make it look neat / semi-original.
STAATS
Old Thu, Jan-03-2019, 03:33:55 PM   #32
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
Awesome, Ian.
Mr. Wolfe
1994 Porsche 911 Factory Widebody
Old Sat, Jan-12-2019, 08:15:25 AM   #33
STAATS
STAATS's Avatar
Any update on the project or your cooling duct routing?
STAATS
Old Sat, Jan-12-2019, 12:31:11 PM   #34
Not yet. This is one of many front end projects for this winter, and I can't proceed with it till my new wheel bearings arrive.
Last weekend I did swap the springs, swap the steering rack, install the Hard backing plates (which are pretty shit quality/fitment, imo), and some other little things
Old Sat, Jan-12-2019, 02:40:26 PM   #35
herrubermensch
herrubermensch's Avatar
Reputation: 0 herrubermensch is on a distinguished road
Yeah, I had to spend nearly an entire day cutting and grinding the Hard backing plates for my E39 M5 to get them to fit. They were not even close.
--Peter
Jump to top herrubermensch is offline   Reply With Quote
Old Sun, Jan-13-2019, 12:44:00 AM   #36
STAATS
STAATS's Avatar
Hmm I remember the quality being good but I do remember having some small fitment issues... didn't have to mod anything like some people think they have to but I think the top bolt mounting arrangement took a bit of finese... it's the kinda think I would have just fabbed myself if I had access to a workshop but seemed easy enough to buy haha.
STAATS
Old Fri, Feb-08-2019, 03:11:39 PM   #37
I've had a rethink on how I'm going to route it through the undertray.
I'm going to pass it through right below the sway bar mount bracket. But, instead of drilling a 3" hole and sticking the tube through, I'm going to print a bracket. On the far side I'll add some BMW under trim screw clips. The bracket will pass through and insert into another bracket on the other side. Screws will pass through the outside bracket, then through the underbody panel, then into the far side bracket with attached screw clips. This should minimize the hassle for any project where the undertray has to come out, or where I need the ducting out of the wheel well for car work, and make replacement hose easier (and less of it required) if something happens to the hose in the wheel well.
Inside bracket:
Outside bracket:
3 screws will take everything apart, while leaving the hose clamped onto the bracket
Old Fri, Feb-08-2019, 03:46:52 PM   #38
BTB
BTB's Avatar
Awesome stuff here, must've missed it the first time around. Just what I was planning to do down the road (no fogs track car), looks even better than I'd hoped. Can't wait to see it all finished and see what you price your 'M3 fog delete brake duct kit' at
My Journal
Old Fri, Feb-08-2019, 03:54:07 PM   #39
I suspect I'm just going to upload the files-- don't think there's anyone or any way to produce this.
Old Fri, Feb-08-2019, 03:56:09 PM   #40
BTB
BTB's Avatar
Even better. Can't wait to see pics with the bumper buttoned back up and both ducts in
My Journal
Discussing 3D printed brake duct project update. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
