Old Fri, Dec-28-2018, 12:43:58 AM   #21
daveishi
Reputation: 0 daveishi is on a distinguished road
Default Re: 3D printed brake duct project update.
Hey Obioban, nice work!
Btw Iíve got a set of brand new Hard Motorsport 355 rotor backing plates that Iíll be selling if youíre interested, havenít listed them yet but saw those were part of your plan.
2004 Mystic Blue Metallic/Grey Black 6MT
Jump to top daveishi is online now   Reply With Quote
Old Tue, Jan-01-2019, 08:59:11 PM   #22
bimmerrodg
bimmerrodg's Avatar
Reputation: 0 bimmerrodg is on a distinguished road
I can't, as I don't have the stock washer tank anymore.
Obioban, witch tank are you running?
Jump to top bimmerrodg is offline   Reply With Quote
Old Tue, Jan-01-2019, 10:33:59 PM   #23
I'm running an e39 high intensity washer tank in the drug bin, as part of my quest for 50/50 weight distro on my 3080 lb fully interior car
Old Tue, Jan-01-2019, 10:59:58 PM   #24
bimmerrodg
bimmerrodg's Avatar
Probably-- someone would have to check the clearance between the washer tank and fog light (If there's room to add a brake duct in there). I can't, as I don't have the stock washer tank anymore.
Wow! Impressive! Any diy on this? Same pump?
Old Tue, Jan-01-2019, 11:06:21 PM   #25
It is the same pump. I just made a mounting bracket, extended the wiring, and rerouted the pump fluid line. Don't know of any DIY for it.
Old Tue, Jan-01-2019, 11:18:49 PM   #26
bimmerrodg
bimmerrodg's Avatar
Perfect thx!
Old Wed, Jan-02-2019, 03:51:54 AM   #27
STAATS
STAATS's Avatar
I'm interested to see how you route the 3" ducting line from that into the Hard Motorsport backing plate...
I currently have the Hard Motorsport 355mm backing plate but fo my feed I have just modified some CF foglight covers (basically these ones: https://www.alibaba.com/product-deta...154891667.html ... as a side note a wouldn't recommend them, was a terrible fit and took a lot of modifying and still doesnt fit perfect... I just got them as I was buying the CF lip spoiler through them at the same time which was a good fit for aftermarket especially vs the terrible fit of these)... anyway. I have yet to look at actually running the 3" tube between them and the backing plate... when I did some mock ups I was unable to find a way to achieve it without having interference at the very end of travel so may require some travel limiters (which as a side note I may very slightly need for full lock due to my suspension / wheel fitment so may not be the end of the world)
I was thinking of building a mounting interface connection into the plastic scuff plate just below the cut out for the sway bar... I wanted to cut a 3" whole and then glue a 3" pipe in there. then connect from the back of the fog light to that just using hose clamps and then from that to the back of the Hard Motorsport plate... I found some 3" 22deg gutter bends that I could mount to either end of the 3" line for in the wheel well and as they help make the bend sharper they may actually stop the clash I experienced in earlier test fits but not sure yet... will also make it easily removable so when I'm just on the street I can remove that section and then use a 3" gutter plug to stop junk getting in the wheel well.
22deg gutter bend for reference:
https://www.bunnings.com.au/holman-7...elbow_p4770261
gutter plug for ref:
https://www.bunnings.com.au/holman-7...m-cap_p4770386
(could just simply put a bolt through that onto the mounting pipe and drill a few holes in it to replace the pipe when street driving)
STAATS
Old Wed, Jan-02-2019, 01:26:46 PM   #28
erickrayos
Originally Posted by mcfreid View Post
me wants this.... I was about to say to make something like this that has a scoop for the intake and the other half for the brake cooling duck. I'd pay for it for sure. lol
Old Wed, Jan-02-2019, 03:16:13 PM   #29
bigjae1976
There is a tried and true route for the hose so that there's no interference. You will need to cut the plastic engine cover. You can use these flanges to make the connection easily removable for street driving.
https://www.aircraftspruce.com/catal...uctflanges.php
These are not necessary. If you route the hose right there will be no need to ever remove the hoses.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Jan-02-2019, 05:42:53 PM   #30
aznbo187
XIII
aznbo187's Avatar
Thanks for sharing! Didn't want to end up paying $80 for some flanges from Bimmerworld.
no.13
Discussing 3D printed brake duct project update. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
