Old Fri, Jan-11-2019, 08:43:26 PM   #21
SQ13
Default Coolant Leak Behind Motor. Need Advice.
Bumping this bc I need some help. I replaced all of the coolant lines, and there are zero external leaks. However, I have to keep adding water to the coolant reservoir even after bleeding.. During idle, the level will drop 0.5-1.0 cm from the cold line. If I drive it then immediately check level, itíll go down halfway between cold level and empty. No white smoke from exhaust, oil filler cap does not have oil mixed with coolant. I know these arenít the best ways to check for head gasket failure, but I donít think the car will make it to a shop for a compression and leakdown test.
Edit: This is dumb
Old Fri, Jan-11-2019, 10:49:53 PM   #22
Alpine 318is
Twinscrewed
Reputation: 0 Alpine 318is is on a distinguished road
Default Re: Coolant Leak Behind Motor. Need Advice.
Supercharger doesn't change the job one bit. It's not in the way.
Eurosport Twin Screw would be in the way.
Jump to top Alpine 318is is offline   Reply With Quote
Discussing Coolant Leak Behind Motor. Need Advice. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
