Old Thu, Dec-27-2018, 03:21:01 AM   #11
SQ13
Default Re: Coolant Leak Behind Motor. Need Advice.
The factory clocking of the block side hose clamp is up. You will need to access it from above. I can’t picture how easy the job as whole will be from underneath.
Originally Posted by englishtom1596q View Post
i agree it won't be easy and will result in scraped arms but i'd do that over pulling the intake, replacing gaskets and praying for no vacuum leaks at the end of it.
Another idea is to get an M50 manifold and swap it in at the same time. Upgrade and maintenance at the same time!
I got under the car today, and replacing the hose from underneath looks impossible. First, I can’t see where the hose is going because the starter is in the way, and second, I can’t get my hands in there.
I’ve started the process of intake removal. So far, I’ve removed the front airbox piece and both throttle bodies. I’m gonna search for some decent DIY guides on how to remove the main piece, and hopefully I’ll be able to get that off tomorrow. Which gaskets do I need to replace, just the two manifold gaskets (11611740069)? Looks like they’re $14.22 each on ECS...
Old Fri, Dec-28-2018, 12:34:00 AM   #12
omairtheman1
This job looks like a walk in the park without a supercharger there. Enjoy it and consider yourself lucky. Good time to wrench!
Old Fri, Dec-28-2018, 11:08:40 PM   #13
SQ13
I got the intake off yesterday. Are there parts that I should replace preventively? I知 replacing the four coolant hoses, the manifold gaskets, and throttle body gasket. I知 also cleaning the ICV. Someone suggested that I replace the CCV and the connection flange for the three heater core hoses...is that necessary?
Idk man, it was a shitty experience, and I知 not looking forward to reinstalling it.
Old Fri, Dec-28-2018, 11:35:07 PM   #14
Supercharger doesn't change the job one bit. It's not in the way.
I told you.
The hoses that connect to the block, YES, replace.
CCV and drain hose are a good idea while in there.
Old Sat, Dec-29-2018, 05:09:11 AM   #15
omairtheman1
You're right but I remove because I hate not having enough access room. Especially the 4th hour wrenching.
Old Sat, Dec-29-2018, 03:55:45 PM   #16
SQ13
I told you.
I mean, I didn稚 doubt you..I knew it would suck lol. But I値l probably do a better job than most of the BMW shops in Houston ッ\_(ツ)_/ッ
Okay I値l order the two throttle body hoses and CCV as well. The two larger hoses up front have already been replaced. Please let me know if I missed anything.
Old Sat, Dec-29-2018, 09:38:26 PM   #17
JitteryJoe
Check the vanos oil line hose. It is fully exposed and easily accessed right now.
Never ask "what should I do while I'm in there?". The list ends up being just short of a full rebuild
Jump to top JitteryJoe is online now   Reply With Quote
Old Sun, Dec-30-2018, 12:19:58 AM   #18
SQ13
Part number 11361705532? I was looking at that line, and it looked like it had been replaced somewhat recently. I don’t mind replacing it again so it can be documented.
Oh I know how it works. A few years ago, I was going in to install subframe reinforcement plates (~$120) on the E46 and ended up ordering around $2k worth of parts
Old Sun, Dec-30-2018, 05:05:05 AM   #19
omairtheman1
That and Oil Filter Housing gasket... I mean it's only an alternator removal away!
Old Sun, Dec-30-2018, 05:36:18 AM   #20
SQ13
Oof. I think I壇 need to drain the oil, but I just changed the oil last summer.
Copyright ゥ1999-2017 M3Forum.com
Discussing Coolant Leak Behind Motor. Need Advice. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
