Old Fri, Dec-14-2018, 08:44:51 PM   #1
JitteryJoe
Default Steering joint assembly now available
These have not been available for a couple of years. I just noticed they are now back in stock. Just in case anyone has been looking for one.
Part#: 32311159866
http://www.realoem.com/bmw/enUS/show...diagId=32_0640 Item #2 (steering shaft)
Old Fri, Dec-14-2018, 10:12:21 PM   #2
craigjimc
Reputation: 0 craigjimc is on a distinguished road
Default Re: Steering joint assembly now available
E34 M5 u-joint works better - part # 32 31 1 151 454.
Jump to top craigjimc is offline   Reply With Quote
Old Sat, Dec-15-2018, 12:52:26 AM   #3
JitteryJoe
I talking about the shaft assembly, not the u joint
Old Sat, Dec-15-2018, 02:45:52 AM   #4
craigjimc
Sorry.
Old Sat, Dec-15-2018, 12:23:33 PM   #5
omairtheman1
Joe, did yours have play in it? I don’t recall when I changed the shaft Guibo that mine had any play.
Thank you,
Omair
Old Sat, Dec-15-2018, 03:19:08 PM   #6
JitteryJoe
Originally Posted by omairtheman1 View Post
Joe, did yours have play in it? I donít recall when I changed the shaft Guibo that mine had any play.
Thank you,
Omair
Mine just looked well worn. I was going to change it as preventative maintenance since I had everything disassembled. This quite some time ago and when I went to order a new one I found they were no longer available. I just received a notice that they are now available which I found as a bit of a surprise so I posted in case anyone had a need. Some of the parts for these cars are getting harder to find (e.g. Power Steering pump).
Old Sun, Dec-16-2018, 03:28:12 AM   #7
Reauxtide
Reputation: 0 Reauxtide is on a distinguished road
As soon as I got the email saying it was back in stock I ordered it.
The plastic/rubber was gone around 2 of the u-joint caps at the top of the shaft. I only had a little bit of play, but knew it was a matter of time before all lubrication would be gone.
I keep hoping as e36 prices trend up OE and BMW suppliers will start to bring back more of the important NLA pieces.
Jump to top Reauxtide is offline   Reply With Quote
Discussing Steering joint assembly now available in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
