Old Mon, Dec-10-2018, 03:39:49 AM   #1
Euro Spec 73
Reputation: 0 Euro Spec 73 is on a distinguished road
Default 1998 323is Serpentine pulley tensioners hydrolic or Mechanical?
How's it going everybody?
I have a 1998 BMW 323is my question is does anybody know if the tensioner pulleys for the serpentine fan belt are hydraulic or mechanical?
I called up my dealer and I gave them the last 7 of the vin and they can't even answer it's so frustrating any real answer will be highly appreciated thank you.
Jump to top Euro Spec 73 is offline   Reply With Quote
Old Mon, Dec-10-2018, 03:44:16 AM   #2
Default Re: 1998 323is Serpentine pulley tensioners hydrolic or Mechanical?
Go out and look. BMW used BOTH randomly on late model cars. Nobody can tell you.
Old Mon, Dec-10-2018, 05:20:49 AM   #3
bluptgm3
Though inserting the last seven of your VIN should reveal the answer, www.realoem.com.
Look at it, as mention above.
Old Mon, Dec-10-2018, 05:22:22 PM   #4
Euro Spec 73
Okay thanks Blupt For letting me know I'll have to check out that site again.
Old Tue, Dec-11-2018, 06:38:33 AM   #5
M3AN
321 fun...
M3AN's Avatar
New Zealand
Actually VIN+RealOEM isn't any good for tensioners because as @Braymond141 says above random cars came with mechanical tensioners.
But... if you're just replacing the tensioner(s) get hydraulic ones to replace whatever you have.
I think you need different bolts if you're going from mechanical to hydraulic but that's it. You can by the lot as an exchange kit (e.g. https://www.bimmerworld.com/Engine/P...-X5-Z3-Z4.html).
E36 M3 Coupe | S50B32 | 6MT | Estoril | Simota | Remus | Bilstein | Eibach | BBS | Goodyear
Old Thu, Dec-13-2018, 05:16:38 AM   #6
HoneyBunches
Reputation: 0 HoneyBunches is on a distinguished road
Looking is good advice because it will show you how to get better at solving problems independently of others!
However on your vehicle the tensioners are most likely mechanical on the alternator side, and hydraulic on the A/C side.
If you're swapping this part because it is "chirping" or sounds like there is a squirrel under there at idle it might just be the idler pulley(s). These can be removed from the tensioners without taking the whole tensioner off (on either side). Yes, belts still have to come off at least part way.
Jump to top HoneyBunches is offline   Reply With Quote
Discussing 1998 323is Serpentine pulley tensioners hydrolic or Mechanical? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
