Old Thu, Nov-08-2018, 06:00:49 PM   #1
skillzo1
skillzo1's Avatar
Reputation: 0 skillzo1 is on a distinguished road
Default RTD Reverse Lockout Shifter. No trimming interior.
Thought id share a new product that RTD is releasing. No trimming of center console is needed. No drilling new holes in trans tunnel.
Current 05 IB//BL 6SPD 714RWHP 590TQ
SOLD 05 AW//IR 6SPD
Skillzo's Build...http://www.m3forum.net/m3forum/showthread.php?t=487768
Jump to top skillzo1 is offline   Reply With Quote
Old Fri, Nov-09-2018, 02:48:09 AM   #2
e46Dan
Reputation: 0 e46Dan is on a distinguished road
Default Re: RTD Reverse Lockout Shifter. No trimming interior.
This must be a new model. When I ordered several months ago, they weren't making lockout shifters anymore.
Jump to top e46Dan is offline   Reply With Quote
Old Fri, Nov-09-2018, 03:12:17 PM   #3
skillzo1
skillzo1's Avatar
They stopped making the old version cause they was designing this up. The goal was to have it work without needing to cut into the interior.
SOLD 05 AW//IR 6SPD
Old Fri, Nov-09-2018, 03:20:01 PM   #4
M3AZ
///M3AZ
Reputation: 0 M3AZ has disabled reputation
Is the point of this so you don't shift into reverse when you really want to put it in first?
Jump to top M3AZ is online now   Reply With Quote
Old Fri, Nov-09-2018, 03:26:10 PM   #5
2006E46M3fan
2006E46M3fan's Avatar
Sweet. Now I think they should have a black Friday early adopter sale.
Jump to top 2006E46M3fan is offline   Reply With Quote
Old Fri, Nov-09-2018, 05:37:54 PM   #6
ethan
Reputation: 0 ethan is on a distinguished road
That, but more importantly it lets you push hard to the left with the shifter on a 3->2 downshift and not go past the 2 gate. When you have a lot of leverage from a longer shifter, it's pretty easy to overpower the spring in the bellhousing which keeps you from accidentally traveling too far laterally and passing right over 2nd.
Jump to top ethan is offline   Reply With Quote
Old Fri, Nov-09-2018, 05:41:16 PM   #7
M3AZ
///M3AZ
That's a more compelling reason. Can this be retrofitted to non-lockout RTD shifters?
Old Fri, Nov-09-2018, 05:46:40 PM   #8
skillzo1
skillzo1's Avatar
I dont believe it can but id ask rtd.
SOLD 05 AW//IR 6SPD
Old Fri, Nov-09-2018, 11:28:25 PM   #9
aa240sx
aa240sx's Avatar
Reputation: 0 aa240sx is on a distinguished road
I would be curious about this as well. The improvement I would like to see on this shifter is one that already exists in a few other floor mounted shifters like CAE.
I would definitely like to see some way of adjusting shift points in more than just 3 to 4. Namely, 1 to 2!!!
- 2003 M3 Coupe - Alpine White - 6 speed - RTD Short Shifter, Enkei RPF1's on Hankook V12 staggered, Macht Schnell Intake, Eisenmann Exhaust, Koni's on Vogtland springs, Status Gruppe front lip.
- 2008 Mercedes Benz R350 - stock
- 2002 330i - Gray Metallic - 5 speed sport package - stock
Jump to top aa240sx is offline   Reply With Quote
Old Fri, Nov-09-2018, 11:31:03 PM   #10
aa240sx
aa240sx's Avatar
If this is true, then my earlier statement is null and void as this appears to effectively provide a stop for 3 to 2 shifting!
Definitely curious if this can be purchased and added to existing RTD shifter. I'M IN!!
Discussing RTD Reverse Lockout Shifter. No trimming interior. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
