Old Wed, Jul-25-2018, 10:43:34 PM   #11
Maxima SE
445 FTW
Maxima SE's Avatar
Reputation: 0 Maxima SE is on a distinguished road
Default Re: Best subframe repair options as of July 2018?
Not fully assessed yet. At least one crack is visible with the subframe in place, so I'm expecting the damage to be pretty bad, possibly enough to necessitate replacement.
It is very hard to fully inspect the RACP unless all the dirt and grime is sanded off down to the bare metal to find all the cracks etc but if you have separation anywhere with floor dropping then I would consider replacing the whole thing. I would start by looking inside the trunk around the wheel well area to see if you have signs of seperation. The idea is hard to digest but sometimes a new RACP is the only way to go and really not that much more money or labor compared to fixing extensive damage. Last thing you would want is to throw thousands at an already fatigued sheet metal and cover it up with a bunch of bandages with uncertainties about its durabilty.
2005 6MT Phoenix Yellow///M3
Jump to top Maxima SE is offline   Reply With Quote
Old Wed, Jul-25-2018, 10:48:57 PM   #12
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Originally Posted by Dr M3an M3 View Post
If you don't already have reinforcement plates, Redish plates have been the 'Gold-Standard' here.
To reach Vince, checkout his FB page, where he is more active (if you haven't already):
https://www.facebook.com/PPRnDnews
vincent@practicalperformance.se
Another option (No personal experience outside of reading his posts on here) is CMP Design (Australian) -- Very similar to the VinceBar. Same idea. By the looks, this option likely weighs a bit more and is not totally hidden like the VinceBar...but something to consider, especially if you can't get ahold of Vince.
http://www.m3forum.net/m3forum/showthread.php?t=565038
Honestly, it wouldn't be hard to get a local metal fab shop to fabricate up a "VinceBar". Would be much cheaper done locally (especially since you avoid international shipping).
Really surprised your RACP wasn't already reinforced!
Agree with all of this. Ive felt the CMP one and it is quite heavy. Im not sure the weight difference between the 2 though.
But keep us posted if you get a hold of vince, I was planning to use his also.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable 500lbs Front 600lbs Rear/TCKline Camber Plates/TMS Adjustable Rear Control Arm/Powerflex Black RTABs/Turner Delrin FCABS/ Brembo GT 6 pot F 4 Pot R/OEM CSL Trunk/ SGT 1 piece lip
Jump to top Sandeep1212 is offline   Reply With Quote
Old Wed, Jul-25-2018, 11:49:05 PM   #13
Hmm, I'm not a fan of CMP's design being visible after everything is done. Sent Vince an email, but based on his comments on facebook, I'm not too hopeful about being able to get a full kit in a reasonable timeframe.
Maybe brand new RACP + Redish plates + foam might be the way to go
Old Thu, Jul-26-2018, 12:09:16 AM   #14
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
See if he has any of the gussets in stock. I had Vince send me everything for the weld kit, aside from the long square metal bar -- WAY cheaper to source locally and have welded in than to have him ship that huge piece from Scandinavia. Honestly, if you look at the design, it should be easy for a local metal fab shop to recreate it....especially if they are going to be doing all the labor installing it. I'd think any shop that does cages would find this to be simple to recreate for you.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2 ...and more to come!
Old Thu, Jul-26-2018, 12:19:37 AM   #15
Maxima SE
445 FTW
Maxima SE's Avatar
I went with brand new RACP with reddish plates mounted onto it, mason X brace bolted in through the RACP and welded onto shock towers from the above. for the front I did the vince front gussets. then my RACP was extra welded all the way around, and especially around the RTAB area. I think it does the job and you walk away knowing that you've got a reinforced stress free RACP in there. Parts would be about $2000 and another $3000 or so in labor. the vince bar requires too many additional hours of labor over the mason x brace which is probably just as effective but way easier to install.
Old Thu, Jul-26-2018, 12:33:04 AM   #16
walid.m3
walid.m3's Avatar
Reputation: 0 walid.m3 is on a distinguished road
If you trunk isn't sinked in, it should cost less than 3k. My trunk sinked in on the left side. It cost me 3k. I had Piper Motorsports do it, and 2 and half hours away from Philly.
However he fabricated all the plates for me. Send me a PM, and I will send you the work he did for me. Mine was badly cracked.
Jump to top walid.m3 is offline   Reply With Quote
Old Thu, Jul-26-2018, 01:18:49 AM   #17
Toasty
Reputation: 0 Toasty is on a distinguished road
I actually just tried emailing Vince two nights ago myself about getting a VinceBar and the supporting accessories. I still have not heard from him, and while I'd prefer not to pester him while's he's trying to handle more pressing and personal issues in his life... I'd also like to be able to drive my car without worrying about my subframe failing further. The suggestion made in this thread to try and get in touch with him via Facebook sounds like it could be a good one. Again, I would hate to bug him, but I may attempt the FB route if I don't see an email from him in the next few days.
Also, speaking of M3 community members who I really like but occasionally seem to have trouble getting in touch with, I got what I feel was a pretty reasonable installation quote from Kaiv for installing a rivet/epoxy VinceBar + VinceSkinz kit. And, not only that, but when I last spoke to him he sounded open to reducing the install cost if it turns out Vince's newest version of the VinceBar, which is supposed to be easier to install, does indeed take less time to put in. I don't remember the exact numbers floated around, but I do know the estimate for everything (components + labor) was well under your 5K cap.
Alongside the reasonable total costs I've been quoted, I like Vince's solution in theory as well, and for the moment I still personally feel like his solution is best for me. However, if I can't in touch with Vince soon, then I'll probably be in the same boat as you terraphant, and will need to start seriously looking at alternatives... For now though, I'm going to hold out a little longer. According to Vince's FB page, he just shipped out the first batch of his updated VinceBar about 11 days ago, so I feel he's still making progress.
Jump to top Toasty is offline   Reply With Quote
Old Thu, Jul-26-2018, 01:32:00 AM   #18
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
I just got my vincebar today actually. I ordered it a couple of weeks ago. Iím looking forward to his skinz when those are available.
Side question:
Is it fine to tune solid subframe mounts without plates? I plan to foam the cavity as well.
Jump to top Blaikenstein is offline   Reply With Quote
Old Thu, Jul-26-2018, 06:33:47 AM   #19
Drew Stahlgrau
Sienar Fleet Systems Inc.
Drew Stahlgrau's Avatar
Reputation: 0 Drew Stahlgrau is on a distinguished road
St Vincent and the Grenadines
I recently had the PSDesigns (Redish) RACP reinforcement plates installed. I can't speak to the effectiveness of this kit for severe or obvious preexisting RACP damage. However, I did install this kit mostly as preventative measure (after a tech claimed that he found a hairline crack) and a precursor to a more comprehensive underbody restoration. I chose this kit over the more common (Active, Turner) kits because its plates cover a larger area while also being a thicker gauge metal. I also understand the concerns about cost as it quickly become a slippery slope. As so much has to be removed to install, I took the opportunity to replace/upgrade the subframe bushings (Powerflex), reseal diff, diff bushings,new sways,shifter rebuild, CSB,guibo front control arms etc etc.
At any rate, I'm happy with the solidity of this kit especially when paired with the Powerflex E46 M3 Handling Pack. Incidentally, I also had a front subframe reinforced with Garagistic front plates (along with new motor mounts). To me, for the street and maybe driving school/ light track duty I believe this kit is a fine option.
The Vincebar looks impressive and I considered it along with the Mason engineering solutions but ultimately went with the PSDesigns/Redish kit for my needs.
Current Mods: Brembo GT BBK, Active Autowerke Headers,Rear muffler and tune. MEMO Vanos Lockdown(Beisan), H&R sport,Koni Yellows, Powerflex RTAB,FCAB ,PSDesigns RACP weld-in plates, ST F&R sways, Camber kit, 19" M359,GY Eagle F1,-Keyhole, Euro blind spot mirrors,Stebel Nautilus horn, -CDV,SS clutch line, 330d shifter, ZHP knob, Turner poly shift bushing and Skid plate. LED tails. CSL diffuser. etc. etc
2002 M3 6MT, Jet Black/Black Nappa, Premium,HK,
Daily:2001 325iT 5MT, Jet Black/Grey Nappa, 19" style 167, H&R sport. Koni STR. Active headers, Dinan intake and exhaust, UUC sways, FCAB and RTAB. OEM M3 strut bar,motor & tranny mounts. Roof rack delete. OEM Sport seats and HID retrofit. Etc. etc.
Romans 8:28 "And we know that all things work together for good to them that love God, to them who are the called according to his purpose."
Jump to top Drew Stahlgrau is offline   Reply With Quote
Old Thu, Jul-26-2018, 06:49:52 AM   #20
I would never do foam in case welding is required later.
_
Discussing Best subframe repair options as of July 2018? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
