Old Fri, Oct-05-2018, 11:37:18 PM   #181
haas16
Reputation: 0 haas16 is on a distinguished road
Default Re: Best subframe repair options as of July 2018?
Originally Posted by Chapelle View Post
If you have a welder who is experienced with this job or can weld thin sheet metal, that seems to be the preferred method. If not, it becomes very easy to create more problems with ineffective or burned through welds.
Epoxy is used in several automotive and aeronautical applications where its strength can be relied on in the harshest environment.
Either application can be ruined without proper pre and post-treatment such as rust removal and undercoat protection.
I went with welded because my installer had done several jobs prior.
Thanks for the info. Iíll check with the shop I was going to go with if they have a welder who does these well.
Jump to top haas16 is offline   Reply With Quote
Old Sun, Oct-21-2018, 01:15:14 AM   #182
I've been awake nearly 40 hours and completed 28 hour shift earlier, so this will be quick.
Just to update this thread - I dropped off my car at Matt's (Coinage) shop about 2 weeks ago and picked it up today. Car was actually done earlier, but I couldn't pick the car up until this morning due to my schedule.
As we knew, my car had some cracks. All in all it didn't look as bad as some other samples I've seen, especially considering my car has 170k miles. Worst of it was apparently the wheel arch edges, which I don't have a good picture of (Matt might). On the floor itself the front right mount was the main damage, which you can see below:
Cracks were repaired, Redish plates were welded in, and everything was rust proofed. He described the rust proofing as:
I use POR15 on the bare metal and a 3m undercoating top coat to fill any small voids
Here's a picture of how that ended up looking:
Then from the top, a VinceBar (I believe the new design?) was installed, along with his front gusset cups. I don't currently have good pictures of that.
While he was in there, I also had Matt do the following:
Replace diff bushings (stock)
Replace diff seals/fluid
Replace subframe bushings (stock)
Replace RTABs (Turner Monoball V2.0)
Replace Trailing Arm Ball Joints (stock)
Replace Lower Control Arms (Ground Control Sealed Ball Joint Camber Arm)
Replace Upper inner control arm bushings
As far as my impressions: It's pretty much what I was going for. The car feels more solid from the driver's seat without really impacting the character or quality of the ride. I can shift through gears quickly without upsetting the balance of the car and I can give pretty much full power out of corners without feeling uneasy. Ride quality wise it's absolutely no worse than before I brought in the car, and may actually be improved over uneven surfaces and such. I've heard of people complain of some harshness over road reflectors, uneven pavement, expansion joints, etc when using monoball RTABs. I get none of that.
Perhaps most importantly, I can now drive this car as hard as I want without having that worry at the back of my mind of destroying my rear end.
In hindsight, I think I should have gone with solid rear subframe bushings since apparently those don't add any NVH, but I'm happy with how everything turned out nonetheless. From what I hear, there may be a replica of the BMW Motorsport subframe bushings at some point in the future, and I may go for those when the time comes.
Old Sun, Oct-21-2018, 01:22:07 AM   #183
Exclusivs
Exclusivs's Avatar
Reputation: 0 Exclusivs is on a distinguished road
Must feel good! Nice work, and agree with your assessments. Did you go w weld/or rivet VinceBar? A complete refresh of bushings / balljoints / arms + solidity of Reddish plates/ and top bar. Very nice! Glad to hear the car is fully sorted!
Jump to top Exclusivs is online now   Reply With Quote
Old Sun, Oct-21-2018, 01:26:12 AM   #184
I went with the weld kit. Matt was more comfortable with welding, and with there being cracks present, it's not like welding could have been avoided altogether anyway. If I had a low mileage car with no cracks whatsoever, I would have pushed for epoxy + rivets.
And yeah definitely figured I may as well do it right and do everything in the rear end while we're at it. My wallet is definitely lighter now, but it's something that had to be done if I intend to keep this car long term (which I do). At this point, not a single bushing on the car is original to the car (though my front end could perhaps use a 2nd refresh).
Old Sun, Oct-21-2018, 01:31:40 AM   #185
Exclusivs
Exclusivs's Avatar
Awesome job! Agree half the battle is using what you/or installer are comfortable/ have experience with. Enjoy the solid refreshed rear end feeling for miles to come!
Old Sun, Oct-21-2018, 04:58:31 PM   #186
mrgizmo04
mrgizmo04's Avatar
Nice, enjoy!
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sun, Oct-21-2018, 05:04:22 PM   #187
mcfreid
Reputation: 0 mcfreid is on a distinguished road
Nice, this is exactly what I'm hoping to have Matt perform on my car this winter! Glad to hear it went well. Now just waiting for Vince to replenish his stock of weld-in vincebars.
Jump to top mcfreid is online now   Reply With Quote
Old Fri, Jan-11-2019, 08:04:41 PM   #188
tdott
Reputation: 0 tdott is on a distinguished road
Trying to decide what to do here in 2019.
I have a 2001 6spd M3 vert w/118k miles I just picked up. Had to do some rear end work. (RTAB, Ball joints) Decided to drop the sub-frame. I cleaned up the mounting points and confirmed there are no cracks.
After reading everything, it seems like just doing the plates won't prevent issues. Being a vert, this is planned to be a weekend cruiser, no track/drag strip here.
Should I just clean everything up, change everything I am there for and put it back together? Hmm, originally I was planning to weld or epoxy a set of plates in as I assumed that was the best approach, but I haven't ordered a set yet. Now I am not so sure anymore...
First E46 M3 yay.
Had several other Ms and BMWs.
Jump to top tdott is offline   Reply With Quote
Old Fri, Jan-11-2019, 08:16:40 PM   #189
Aeko
Aeko's Avatar
Reputation: 0 Aeko is on a distinguished road
First E46 M3 yay.
I'm of the opinion I'd rather pay a little now than a lot later. Putting some money into doing the plates now, especially while it's apart, is a wise idea considering M3s are especially susceptible to it. It also increases the resale appeal should you ever decide to do so. Even just changing the subframe mounting bushings to solid should help prevent issues.
An aside.. I just bought my first M3, an '02 coupe @137k. Initially I thought I could get away with just reinforcement (turns out it has some nasty cracks). I did a lot of research on this and what I've come across tells me that while epoxy is strong, in most situations it will be prone to moisture being trapped during the application process and may eventually fail. As much as I'd like for the epoxied plates to be viable, welding may be the only option. I'd do it myself but I don't have anywhere I can use a welder.
Jump to top Aeko is online now   Reply With Quote
Old Fri, Jan-11-2019, 09:50:53 PM   #190
Goose81
Reputation: 0 Goose81 is on a distinguished road
Mind me asking what all this cost you?
Jump to top Goose81 is offline   Reply With Quote
Discussing Best subframe repair options as of July 2018? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
