Old Fri, Jan-04-2019, 01:05:38 PM   #91
bimmerteknik
Reputation: 0 bimmerteknik is on a distinguished road
Default Re: 500k+ Mile E36 M3
Originally Posted by M3AN View Post
The rear camber bolts really are a shitty design, I feet your pain.
But more importantly, I'm afraid that without RTAB pocket reinforcements you're looking at an imminent failure with those bushes... you need to see to that promptly. Unfortunately this means your alignment was burnt cash.
I personally have no problem with poly RTAB's, I've been running them for years but you 100%, absolutely, need welded reinforcements.
Edit: those control arms look nice, are they alu?
Thatís good info, Iíll look into getting the reinforcements. Luckily alignments only cost me about 20min if my time. I usually adjust the alignment on my ZHP a few days before a track day and set back a few days after.
Jump to top bimmerteknik is offline   Reply With Quote
Old Sat, Jan-05-2019, 03:54:47 AM   #92
bimmerteknik
Just noticed the edit, no they arenít. They weigh quite a bit more than the OE arms too. But I had them on hand so 🤷*♂️
Old Sat, Jan-05-2019, 04:34:10 AM   #93
M3AN
321 fun...
M3AN's Avatar
New Zealand
A control arm in the hand is worth two in the shop... or something like that!
E36 M3 Coupe | S50B32 | 6MT | Estoril Blue | Z3 Rack | Simota Intake | Remus Exhaust | Bilstein B6 | Eibach Pro+ | 18" BBS RC | Goodyear F1 | 3.62 Gear Set (Yet To Be Installed)
Old Sun, Jan-13-2019, 12:07:29 AM   #94
bimmerteknik
about 9.5 hours invested in the car between last night and today.
Replaced the rear wheel bearings, re greased and replaced inner and outer boots on the axles. Installed stainless brake lines. Cleaned and painted the calipers and carriers. Replaced front and rear pads and rotors, did a pressure bleed on the brakes.
Old Sun, Jan-13-2019, 05:02:49 PM   #95
Kraftwerk
We Are The Robots
Reputation: 0 Kraftwerk is on a distinguished road
Impressive work to say the least, amazed.. awed. This one might see 1 million.
jt
1996 M3 Estoril
1983 911 SC Schwartz Metallic
1999 MX 5 Mica Green
Jump to top Kraftwerk is offline   Reply With Quote
Old Mon, Jan-14-2019, 02:16:42 AM   #96
M3Power2
M3Power2's Avatar
Reputation: 0 M3Power2 is on a distinguished road
Bimmerteknik - how did you get the outer half shaft CV joint apart?
This looks awesome. I have a 97 M3 on jack stands in my garage that I have replaced the entire suspension, steering and upgraded brakes. Nothing but respect for your wrenching.
Jump to top M3Power2 is offline   Reply With Quote
Old Tue, Jan-15-2019, 05:59:50 PM   #97
bimmerteknik
Thanks! I donít know that I can drive that much lol
Old Tue, Jan-15-2019, 06:04:57 PM   #98
bimmerteknik
I removed the inner joint, then removed the outer boot. The metal cap that is over the joint, I removed that by prying gently and evenly around the perimeter. Once I could rotate it by hand I popped it off with a large flat head and a quick tap from a hammer. At that point it disassembles like the inner. I reused the cap. Got it back on and went around tapping it back into place. It was a lengthy process but if it holds up I feel likely was worth it.
And thanks! I enjoy it.
Old Tue, Jan-15-2019, 11:34:37 PM   #99
BLCKSTRM
Reputation: 0 BLCKSTRM is on a distinguished road
Man, I'm so jealous of you guys with actual professional tools. That rear wheel bearing puller just makes me cry.
Jump to top BLCKSTRM is offline   Reply With Quote
Old Sun, Jan-20-2019, 02:55:22 AM   #100
bimmerteknik
It is nice having access to just about every special tool imaginable.
Discussing 500k+ Mile E36 M3 in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
