Old Sat, Jan-12-2019, 02:38:13 PM   #141
stash1
Default Re: American racing headers Results
Originally Posted by S54 Madness View Post
Ill be installing my ARH on tomorrow... I noticed there is only 1 bung hole on the front collector but I have 2 on the car?? I just pmed the OP but I am not sure what to do with the 2nd O2 Sensor??
Just have a tuner code out 1 of the sensors...you only need 1.
'04 AW/IR...some mods
Old Sat, Jan-12-2019, 05:39:49 PM   #142
S54 Madness
S54 Madness's Avatar
Reputation: 0 S54 Madness is on a distinguished road
I see...
which sensor would I have them code out from the front? I am having Evolve send me my tune so I will have to tell him
Also, the O2 I leave out I am just leaving unpluggerd?
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=234906&dateline=15265  73579
2001 M3 karbonius CSL Air Box / Evolve Alpha N-tune / American Racing Headers 6-1 Catless / Borla Sport Muffler /RE Race Pullies / Mishimoto Radiator & Oil Cooler / Ground Control Coilover Kit Street-School / StopTech Pads & Rotors / Apex Arc-8 / Dunlop Direzza ZII 265 Square Setup / Weight reduction down to 3,133lbs
My Build Journal
http://www.m3forum.net/m3forum/showthread.php?t=604716
Jump to top S54 Madness is online now   Reply With Quote
Old Sat, Jan-12-2019, 09:51:14 PM   #143
S54 Madness
Last question - The Exhaust temp sensor - will this be coded out as well for the tune?
I will dyno my car after headers are installed and post on here... I have the Karbounis airbox, RE racing pullies and eletric fan.... So Im pretty excited to see what results I will see!
My previous dyno was 291whp with a K&N CAI and a borla exhaust - this was corrected SAE numbers on a Dynojet Roller
My Build Journal
Old Sat, Jan-12-2019, 11:14:28 PM   #144
mrgizmo04
mrgizmo04's Avatar
EGT and rear O2 can be left unplugged when you get the new tune.
For the front O2, you will need to make sure you remove/unplug the right bank vs what is in the tune, so coordinate with the tuner.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sun, Jan-13-2019, 12:02:40 AM   #145
S54 Madness
I have 2 bungs for the rear / section 1 part of the exhaust.. I assumed Id put both rear O2s in the rear? So I am to only put ONE O2 in the rear and coordinate with the tuner which one is plugged in the rear aswell?
See below how section one looks on the ARH
My Build Journal
Old Sun, Jan-13-2019, 12:05:39 AM   #146
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
I can only imagine the flap closed helps in some way with low speed/mid throttle drive-ability. Not power in any way. Throttle smoothness maybe?
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable/TCKline Camber Plates/TMS Adjustable Rear Control Arm/Powerflex Black RTABs/Turner Delrin FCABS/ Brembo GT 6 pot F 4 Pot R/OEM CSL Trunk/ SGT 1 piece lip
Jump to top Sandeep1212 is online now   Reply With Quote
Old Sun, Jan-13-2019, 12:14:00 AM   #147
mrgizmo04
mrgizmo04's Avatar
I dont think you need the rear at all unless your tuner wants the readout and to see some calibration. Rear o2 usually sit behind the catalytic converter to monitor oxygen flow behind the catalyst.
'05 M3 6MT coupe
Old Sun, Jan-13-2019, 01:22:03 AM   #148
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Nope.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS 2.5" Twin-Piped Oversized section 2, Rogue Engineering Muffler (soon to be switched), WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune.
Active Group-Buys (PM if Interested): OE CSL Bootlids, Supersprint Headers/Exhaust MEGA thread, New Supersprint Oversized Twin-Piped Section 2 ...and more to come!
Old Sun, Jan-13-2019, 01:34:45 AM   #149
stash1
I see...
Just seeing this, sorry man...just figured your tuner would’ve handled this part for you? Anyway, the ARH system (being designed as more or less a max racing effort system) only has provisions for three O2 sensors—1 pre-cat O2 sensor, and 2 post-cat O2 sensors. I don’t believe that it makes much difference which pre-cat O2 gets deleted, and you can just leave both post-cat O2’s plugged in and your tuner of choice can handle how they set up O2 function. Also, as mrgizmo stated, the EGT gets coded out as well.
Old Sun, Jan-13-2019, 03:50:02 PM   #150
S54 Madness
Thanks for clarifying!
My Build Journal
Discussing American racing headers Results in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
