Old Sat, Jan-12-2019, 06:54:32 PM   #21
henryc
Reputation: 0 henryc is on a distinguished road
Default Re: Bump!!!
Originally Posted by zaharias View Post
That looks very nice!!!
What camber did you have up front and what tire size?
Thanks! Please see below for the specs when the picture was taken;
Front:
Apex ARC-8 18x9 ET30
Michelin PSS 245/40R18
No Spacers & Stock Camber
Rear:
Apex ARC-8 18x10 ET25
Michelin PSS 275/35R18
No Spacers & Stock camber.
I have now over 17K on the B12 / Eibach combo. I would get another set when they wear out. As of today the only change now includes a 10mm Macht Schnell spacer up front which I needed to clear my Stoptech 323 Brake Kit. I have some updated pics below.
Jump to top henryc is offline   Reply With Quote
Old Sat, Jan-12-2019, 07:12:04 PM   #22
Default Re: Eibach Pro S Kit vs Bilstein B12 Prokit
Car looks great!
_
Old Sat, Jan-12-2019, 07:39:05 PM   #23
zaharias
Greece
Thumbs up Re: Bump!!!
Front:
Rear:
Thanks for the info & pics!!
Any rub up front?
Iam on square 9.5x18 ET35 (15mm spacer rear and 5mm front to clear calipers) 265/35/18 MPS4 and i rub up front with -2.5 camber. Car is on Koni yellows and ACS springs and GC street camber plates.
I ordered a set of new Eibach springs cause i want to raise the car a bit (i bought the ACS springs used and with unknown kms).
Jump to top zaharias is offline   Reply With Quote
Old Sat, Jan-12-2019, 07:40:05 PM   #24
icecream
Registered Apples
icecream's Avatar
Default Re: Bump!!!
Front:
Rear:
I have now over 17K on the B12 / Eibach combo. I would get another set when they wear out. As of today the only change now includes a 10mm Macht Schnell spacer up front which I needed to clear my Stoptech 323 Brake Kit. I have some updated pics below.url]
Thats pretty high praise. Just ordered B6 shocks to go with my eibachs and replace the B4'S I have now.
Do you track at all and what is it that makes you like them so much?
Old Sun, Jan-13-2019, 08:33:27 PM   #25
henryc
Default Re: Bump!!!
Car looks great!
Any rub up front?
Thanks guys! No rubbing up front.
No, I have not tracked the E46 M3 although itís on my bucket list for things to do with the car. Itís a street car and the intent of my ďbuildĒ was a balance of sport / luxury.
I like them because they do what I wanted from a street suspension;
1. Itís lowered enough for looks (but not too low) without impacting daily drivability. I have no issues driving this in all sorts of streets of LA, up any steep driveways or speed bumps. Iíve never scraped the belly pan or bumper with the B12 going up or down all sorts of steep driveways.
2. The B12 allows road feedback but without being harsh. I donít have complaints from passengers although they do comment its ďsporty but not uncomfortableĒ. But they are coming from plush Lexus SUVís. Iím coming from a Mk4 R32 with H&R RSS coilovers. That made the R32 interior rattle after 20K miles and I did not want that to happen to the M3.
3. Performance - thereís significantly reduced body roll from the SACHS stock setup. However if you push it close to 9 or 10/10ths thereís still a little bit of body roll. Iíve taken it a few times up ACH / canyon roads and the handling is great.
4. Price point. I was looking to spend up to $1K max for a quality spring / shock setup.
5. Perceived service life. If I can get 80K out of the B12, Iíll be very happy.
6. Name brand / OE quality. The engineering and R&D is all done so I donít have to worry about it.
Discussing Eibach Pro S Kit vs Bilstein B12 Prokit in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
