Old Fri, Dec-21-2018, 08:42:32 PM   #711
Al Soobie Guy
Reputation: 0 Al Soobie Guy is on a distinguished road
Originally Posted by AmpTree View Post
I think I screwed up somewhere in the flashing. Now when I turn on the ignition trying to redo the flash, Fuel pump does not prime, the shift lights max out to red, and the engine temperature gauge max out to red as well. No errors in the EWS and cables are all connected. Getting error in INPA as well when checking for codes *
The only improvement I had was hard resetting the car by removing the battery for few minutes yesterday. Surprisingly manage to crank the car, but still couldnít get the car to start. I think itís because of the fuel pump did not prime for any fuel.
Also, I couldnít get to reflash the car, keep getting error 211 battery voltage low. Bought a brand new charger and a brand new battery, but still getting the same error. Iím out of my wits now disconnected the battery and leave it overnight. Will try to see if any good progress or not today.
Sounds like there was an error when you were trying up flash the DME. Its not the end of the world. Fire up ISTA, if DME is " blue" its not initialized and it needs to be reflashed.
99% chance you had this happen is USB cable and/or insufficient power supply for coding.
Right way to fix it is IOTA DLS90 and Icom Next. If you use the right equipment this wont happen.
Good news is that its very likely easily fixable.
Jump to top Al Soobie Guy is offline   Reply With Quote
Old Fri, Dec-21-2018, 08:44:59 PM   #712
Kenny167
Reputation: 0 Kenny167 is on a distinguished road
This issue has since been fixed (to my knowledge). He got the car to start, so I believe he's all set.
Jump to top Kenny167 is offline   Reply With Quote
Old Sun, Dec-23-2018, 08:29:12 AM   #713
AmpTree
AmpTree's Avatar
Reputation: 0 AmpTree is on a distinguished road
Malaysia
Thanks to Kenny for the help. Very much appreciated. Merry Christmas to all, and have a great 2019 ahead
Jump to top AmpTree is offline   Reply With Quote
Old Mon, Dec-31-2018, 05:45:08 PM   #714
e36man
Reputation: 0 e36man is on a distinguished road
Originally Posted by mitesh33 View Post
You donít need the Gear Postion Sensor (GPS) wired, everything still work as it is, cruise control etc
Clutch Pedal Switch Wiring Without GPS Sensor:
In order to make the cruise control work, without the Gear Position Sensor (GPS), Youíll need to make sure you have genuine e46 m3 Clutch Pedal Switch (goes on the clutch pedal inside the car) you cannot use any other e46 one, although they look the same physically, cruise control wonít work if you donít have the proper e46 m3 one.
A total of three wires need to be wired to the Clutch Pedal Switch:
Pin 1 Br/Sw (Brown w/Black stripe): Ground (tap into the brake light switch on pedal box that has the same wiring colours
Pin 2 Wire To X60002/Pin 20 To in the engine bay fuse box, I ran it through a grommet under the fuse box behind the glove box.
Pin 3 Vi/Ge (Violet w/Yellow Stripe): 12V (tap into the brake light switch on pedal box which has the same wire colours).
In USA you can have press the clutch to start, but I donít see why you need that feature, we donít have that in the UK.
If you do want that added then
Pin 4: Bl/Sw (Blue w/Black Stripe): Pin 8 in EWS (white box in upper lefthand side of driver's footwell. Pin 8 is empty). If you remove the two 10mm plastic nuts that hold the EWS module in the footwell, you will be able to see the pin numbering scheme to be sure you make the correct connection. Pin 8 is in the upper right hand corner of the small pins. Again, in order to insert the female pin into position 8 in the EWS connector, you will have to disconnect and then disassemble the connector itself.
Youíll have to enable the Press Clutch To Start function via NCSExpert
If switching to the manual euro harness and installing the GPS, is this still the correct wiring?
The Golden Rule of Wheels: Strong, cheap, light... pick two.
2004 Individual Estoril M3 - M-Textur - Moton - Recaro A8 - FIKSE - Supersprint V1 Catted - Lightwerkz - Z4MC Rack - Solar Power Sunroof
Jump to top e36man is offline   Reply With Quote
Old Sun, Jan-13-2019, 01:35:05 AM   #715
If you're using a manual harness, connect your clutch switch to pin 7 on the X6011 connector here:
And it should be more or less identical to a real manual car from that point. Your manual harness will take care of the rest of the connections that are involved.
I believe 61138373293 is the part number for the pins that go into that connector
Old Mon, Jan-14-2019, 10:03:15 PM   #716
DataDev
Reputation: 0 DataDev is on a distinguished road
Does anyone know of someone in the "Treasure Coast" (central east coast of Florida) that can do this work? I've got a 2004 M3 convertible with 68K that would be great to convert.
Jump to top DataDev is offline   Reply With Quote
